help for Modelling
jaisejames
help for Modelling
Post by jaisejames »
I was trying to do Axial fan. but revolve is not coming correcting. Sectional View and details are there in pdf file
Free cad details
OS: Windows XP
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6700 (Git)
Branch: releases/FreeCAD-0-16
Hash: 7b925d11aa69ac405b423635adb1e2833f18a817
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Fan Details.pdf
(133.76 KiB) Downloaded 30 times
Fan.FCStd
(24.49 KiB) Downloaded 33 times
Willem
Re: help for Modelling
Post by Willem »
Revolving succeeds when you use the revolve function in the Part workbench instead of the revolve in the Part Design workbench
jaisejames
I used part work bench only. but revolving circles shows as lines instead of torus solid.
Willem
Post by Willem »
I do not know what happened. I deleted your revolution and it looked wrong, I created a new one and everything is good. Perhaps it is that you do not have the most recent Freecad version. My specs are
OS: Ubuntu 16.04.1 LTS
Version: 0.16.6707 (Git)
Build type: None
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
Qt version: 4.8.7
Fan_Willem.FCStd
(24.19 KiB) Downloaded 24 times
jaisejames
Thanks for support. I checked your attached file it is showing correcting. when ever I do, it is showing lines. Even I tried with draft circle, same result. I will try with 6706 version.
In between I have notice that circle join dot should be parallel to direction to Z. if not, it will look bump like surface.
Thanks for support.
bejant
Post by bejant »
Willem wrote:Revolving succeeds when you use the revolve function in the Part workbench
@Willem, that is what jaisejames used (maybe you just typed it incorrectly?).
@jaisejames, the problem is that although the Revolve worked, it doesn't render correctly in the 3D view. To fix it, go to Edit > Preferences > Part Design (icon in left pane) > Shape view (tab) and change the Maximum deviation... setting to something like .1 or less. The smaller you make the value the smoother your model will appear but it will take longer for your computer to process the image, so for other models you might want to change it back to the default setting of 0.5.
jaisejames
Thanks it is working now. I changed to 0.1.
I need to create U shape or half torus at the end of sweep rod on both end & attached to face[as in attachment]. I tried with sketch face with linked edge option. But circle become flat on revolve. It is creating flat ring than half torus. Any Idea how to create attached half rings on end of rods.
NormandC
Post by NormandC »
FYI, even if the "Solid" property of Revolve is set to true, it didn't create solid rings. As can be seen from Part CheckGeometry, Revolve is a compound composed of 25 shells, and zero solid.
Apparently, the Revolve tool cannot create solids from an object containing multiple separate closed profiles like the PathArray or even a Sketch.
This is odd, because there is no such problem with the Part Extrude tool, which can create multiple solids under a single Extrude object.
This may very well be a bug with Part Revolve.
jaisejames
My requirement is dia of torus 3mm & inner dia is 60m & gap between torus is 16mm. It keep on increase until say 400mm as shown.
Any other way to create valid solid?
Willem
Post by Willem »
Hi, it is difficult to create solid torusses, I downgraded the array twice in the draft workbench, than you have 25 edges for the 25 circles as a base for the torusses. When I revolve those edges individually they still are not solid. The only way it succeeds is when you draw new circles in the draft workbench with the center of the edges selected. Revolving these circles create solids
About your previous question: Did you succeed in connecting the two headerlines or is this animation still valuable
