I'm detailing my model.
Using the Drawing Dimensioning Workbench (hamish), the Dimension symbols are available, but there are no Weld icons in the toolbar.
I've recently updated the Drawing Dimension workbench via a git pull As well as updated the OS (Fedora 23 to Fedora 25) And I've dropped the persistent toolbar module to see if it would re-scan the Drawing Dimensioning module. I also changed the icon size from small back to the default.
So far no Weld Symbols.
Weld symbols still exist in:
/home/ruchg/.FreeCAD/Mod/FreeCAD_drawing_dimensioning/Gui/Resources/icons/welding
There is a welding python script at:
/home/ruchg/.FreeCAD/Mod/FreeCAD_drawing_dimensioning/weldingSymbols.py
Is this a recent change to the organization of the Drawing Dimensioning Module and I should not expect to see welding icons, or is something happened with my installation and how do I bring them back?
OS: Linux
Version: 0.16.Unknown
Build type: Unknown
Python version: 2.7.11
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Linux 4.8.15-300.fc25.x86_64 #1 SMP Thu Dec 15 23:10:23 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Running Cinnamon
I've lost the Welding Symbols of the Drawing Dimensioning Workbench
Re: I've lost the Welding Symbols of the Drawing Dimensioning Workbench
Sorry for stating the obvious, you may have tried it already: have you right-clicked on the toolbar area to see if the "Drawing Dimensioning Welding Symbols" toolbar was enabled?
- FC_Drawing_Dimensioning_Toolbars_01.png (51.14 KiB) Viewed 2297 times
I don't have the option of turning on the Weld symbols, they don't exist in my world . . . .
- WeldSymbolsMissing.png (79.44 KiB) Viewed 2284 times
OK then, try this: in ~/.FreeCAD, remove from the folder or rename the user.cfg and system.cfg files. When you restart FreeCAD, fresh config files will be created, this will return FreeCAD to its default settings. Maybe you'll get the Welding Symbols toolbar back.
No joy after deleting the two config files.
I did notice in the InitGui.py file:
in my FreeCAD if I would submit the version string to the Python console I get back:
So I'm thinking that the git commit number is coming back unknown and the if statement is failing to do as the programmer intended.
Assuming the git commit number of my FreeCAD is greater than 5166, I hacked the if statement, commenting it out and tweaking the indent level:
I get back the welding symbols.
import weldingSymbols
--> git_commit_no = int( FreeCAD.Version()[2].split()[0] )
if git_commit_no > 5166:
weldingCommandList = ['dd_weldingGroupCommand']
else:
weldingCommandList = weldingSymbols.weldingCmds
self.appendToolbar('Drawing Dimensioning Welding Symbols', weldingCommandList)
self.appendToolbar('Drawing Dimensioning Help', [ 'dd_help' ])
>>> FreeCAD.Version()
['0', '16', 'Unknown', 'Unknown', 'Unknown']
# git_commit_no = int( FreeCAD.Version()[2].split()[0] )
# if git_commit_no > 5166:
# else:
# weldingCommandList = weldingSymbols.weldingCmds
That's the first time I see the missing FreeCAD configuration causing real problems.
The problem with the missing info is that a versioning file is generated at compilation time, but it requires the compilation to be done in a Git repo. The auto-generated source tarball on Github strips the .git folder so if your Linux distro uses it the versioning file cannot be generated. See Incomplete FreeCAD info for Linux packages based on Github source tarball
It should be. The official initial 0.16 release revision number was 6700, there have been 7 bug fixing revisions since then, the latest source is 0.16.6707. Anything before 6700 was a development snapshot.ruchg wrote:Assuming the git commit number of my FreeCAD is greater than 5166
I had opened an issue in hamish2014/FreeCAD_drawing_dimensioning back in May. Now that we know more, I've amplified the original issue on github.
I had hoped it was as simple as providing a compound OR conditional however the line above tries to type cast the 'Unknown' text as integer which throws the error.
Thanks.
Thanks.
