Pocket at an angle
Umayer
Pocket at an angle
Post by Umayer »
I want to perform a pocket at an angle like in the link below. Is this possible?
https://grabcad.com/questions/ho-do-i-c ... at-a-angle
IanP
Re: Pocket at an angle
Post by IanP »
This is a long winded way of doing it, but I cant find away to angle either a pocket or a pad directly in v015 or v016.
It should be possible with an angled projection in v017 but I haven't worked this out yet.
I would hate to try and mill this in any common metal.
V016 version of block.FCStd
(16.13 KiB) Downloaded 118 times
V016 block.JPG (55.3 KiB) Viewed 5904 times
mario52
Post by mario52 »
hi
easy all version
create cube
create sketch
inclination (here 20°) sketch with Euler angle
extrude the sketch
and cut cube with boolean operation
V015VersionOfBlock2.FCStd
(23.36 KiB) Downloaded 151 times
mario
NormandC
Post by NormandC »
Hello mario,
With your method, because the sketch is not on a plane parallel to XY, the arcs in the sketch do not produce cylindrical surfaces, but elliptic faces.
IanP wrote:It should be possible with an angled projection in v017 but I haven't worked this out yet.
All of us need to relearn the software. But it's going to be worth it. (I personally hope we can suggest UI improvements, but I'll try to understand the current UI fully before suggesting changes)
mario52 wrote: V015VersionOfBlock2.FCStd
Are you still using 0.15.4671 mario? The 0.16.6700 Windows installers were posted a couple of days ago.
https://github.com/FreeCAD/FreeCAD/releases/tag/0.16
mario52
Post by mario52 »
hi
NormandC wrote:With your method, because the sketch is not on a plane parallel to XY, the arcs in the sketch do not produce cylindrical surfaces, but elliptic faces.
ok
NormandC wrote:Are you still using 0.15.4671 mario? The 0.16.6700 Windows installers were posted a couple of days ago.
I have 13, 15, 16, 17 une belle collection
mario
NormandC
Post by NormandC »
mario52 wrote:I have 13, 15, 16, 17 une belle collection
:D
Umayer
Post by Umayer »
Thank you all for the suggestions. I think stated my question in the wrong way.
In the image I've attached, you can see that I did a pocket of an half circle. What I want to do is make this pocket a "90 degree turn" to the left.
EDIT: I just found out that in Catia you can use the "Slot" function to achieve this. If this is possible in Freecad, I would appreciate it if someone can tell me.
Umayer
Post by Umayer »
I managed to get it to work. I used the sweep function to get the shape, now I'm trying to cut the part but I keep getting an error.
cox
Post by cox »
Sorry for not responding to your new updated question, but I am playing with 0.17 and used pocket to face with plane as limiting face. Some issue with co-linearity where plane and sketch intersect(moved plane down 1 um)
Could you please post your Freecad file of your last image, quite hard to figure out what you are after
angle slot.fcstd
(23.2 KiB) Downloaded 159 times
Need help? Feel free to ask, but please read the guidelines first
Umayer
Post by Umayer »
cox wrote:Sorry for not responding to your new updated question, but I am playing with 0.17 and used pocket to face with plane as limiting face. Some issue with co-linearity where plane and sketch intersect(moved plane down 1 um)
This is the file
Cut error.FCStd
(40.06 KiB) Downloaded 109 times
