Ticket #2488: Standard paths issues from import SVG to FreeCAD (was: Ellipse issues imported from SVG files)
renatorivo
Re: Ellipse issues imported from SVG files
Post by renatorivo »
Here's my FreeCAD file, only I have not found with Ikscape path 5645, 5557 and 5043, the up arrow, I do not know why it appears.
Bug-renato.FCStd
(39.45 KiB) Downloaded 38 times
renato
renatorivo
QCAD import the same thing as FreeCAD
what's the status of this issue?
oldmachine
Post by oldmachine »
I use CNC mill to machine PCB’s. It’s the reverse of what you’re doing, meaning, I generate an SVG in Freecad, then, open it in Inkscape (or EZDraw) and create a silkscreen layer (if I want one).
I tried using PartDesign and Part workbenches and exporting the SVG. But, always had mixed results until I discovered the main problem: Exporting SVG from PartDesign or Part workbenches does not provide an SVG file type option but, the Draft workbench does and the file opens correctly in Inkscape. (In Draft wb, open Preferences, and set the Import/Export>SVG to Raw for CAM).
Now I can draw what I want in Draft, Export the full list of my drawn items, and Export the SVG. Then, I can open the file in Inkscape and do what I need for a PCB.
The Freecad Draft pref’s also has options for Import - perhaps that’s something you can try…
MAC OSX Sierra
3D Parts & Links (made using FreeCad and Solidworks): https://www.thingiverse.com/Still_Breathing/designs
Android App & Links: https://play.google.com/store/apps/deta ... .bestknots
EdgarRobles
Post by EdgarRobles »
oldmachine wrote: Fri Jan 26, 2018 10:07 pm The Freecad Draft pref’s also has options for Import - perhaps that’s something you can try…
I tested bug.svg file again and it seems better import as geometry option result and some extra points i think those points are from deformed arrow shapes.
Captura de pantalla de 2018-01-28 14-19-28.png (217.21 KiB) Viewed 1479 times
Ellipses apper in segments
Captura de pantalla de 2018-01-28 14-19-57.png (192.72 KiB) Viewed 1479 times
OS: Ubuntu 16.04.3 LTS
Version: 0.17.13125 (Git)
Build type: None
Hash: 59dedd12751a3f5730734741ae6258a4ea4f5745
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 7.1.0
Locale: Spanish/Mexico (es_MX)
also i tested bug-renato.svg file. May be bug.svg file is a damage file because renato's file looks much better.
Sorry to necrobump, but issue #2488 references this thread.
Devs, can you shed light on how to proceed here? Keep the ticket open because of the different SVG export behavior between ParDesign/Part and Draft or close ?
Re: Ticket #2488: Standard paths issues from import SVG to FreeCAD (was: Ellipse issues imported from SVG files)
Syres
Post by Syres »
Kunda1 wrote: Wed Jan 19, 2022 5:55 pm Bumping again issue #2488 as part of an effort to clean up the bugtracker
Is this not the fix, certainly looks like it? https://github.com/FreeCAD/FreeCAD/pull ... a7cc238262
yorik
Post by yorik »
Maybe, but I'm not sure. The fix is for misplaced objects, while here it seems more like a precision problem. But we need to test the attached file again to see
Roy_043
Post by Roy_043 »
Ellipses are fixed.
But arrow heads are not.
Version: 0.20.27129 (Git)
Hash: fcaa698be874323ae26b20d7adf92214989c2d38
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
