Drawing workbench problem
archang
Post by archang »
I insert new drawing, click Page and export to dxf file, when i open the dxf file, no 2D graphics and the following error occurred:
File "/opt/free-cad-code/Mod/Draft/importDXF.py", line 1471, in open
processdxf(doc,filename)
File "/opt/free-cad-code/Mod/Draft/importDXF.py", line 994, in processdxf
drawing = dxfReader.readDXF(filename)
File "/opt/free-cad-code/Macro/dxfReader.py", line 364, in readDXF
drawing = sm.run(infile)
File "/opt/free-cad-code/Macro/dxfReader.py", line 95, in run
(newState, cargo) = handler(cargo)
File "/opt/free-cad-code/Macro/dxfReader.py", line 295, in start_section
obj = handleBlock(obj, infile) # we need to find all there contents
File "/opt/free-cad-code/Macro/dxfReader.py", line 236, in handleBlock
if obj.type == 'block':
<type 'exceptions.AttributeError'>: 'str' object has no attribute 'type'
OS: Ubuntu 14.04.2 LTS
Version: 0.16.4806 (Git)
Hash: a7c346606fe588b0f2faa251e3ae72e9ef833184
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.7.0
S-A-1.stp
(190.69 KiB) Downloaded 41 times
triplus
Re: Drawing workbench problem
Post by triplus »
I did quick test and it works for me. Try to delete DXF libraries from your macro folder and let FreeCAD download them again (Draft WB -> Preferences -> Import-Export -> DXF tab (enable option Automatic update).
If that won't work attach .fcstd file.
archang
Post by archang »
I've tried, the same error occurred!
I use other freecad version, no 2D graphics and the following error occurred:
Version: 0.16.5144 (Git)
Build type: None
Hash: 165261e3584553481209d80e9e0e0332db569959
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
DXF libraries not found. Trying to download...
downloading https://raw.githubusercontent.com/yorik ... olorMap.py ...
downloading https://raw.githubusercontent.com/yorik ... Objects.py ...
downloading https://raw.githubusercontent.com/yorik ... Library.py ...
downloading https://raw.githubusercontent.com/yorik ... fReader.py ...
File "/usr/lib/freecad/Mod/Draft/importDXF.py", line 1471, in open
File "/usr/lib/freecad/Mod/Draft/importDXF.py", line 994, in processdxf
File "/home/archang/.FreeCAD/dxfReader.py", line 364, in readDXF
File "/home/archang/.FreeCAD/dxfReader.py", line 95, in run
File "/home/archang/.FreeCAD/dxfReader.py", line 295, in start_section
File "/home/archang/.FreeCAD/dxfReader.py", line 236, in handleBlock
archang
Post by archang »
.fcstd file
test.fcstd
(25.59 KiB) Downloaded 40 times
archang
Post by archang »
.dxf file
bbb.dxf
(44.94 KiB) Downloaded 51 times
triplus
Post by triplus »
I see the problem now as it's not about exporting but about importing back again the exported DXF file. Yes there is an issue involved and i get the same error if i try to import attached file in FreeCAD. Probably something Yorik will take a look at when he gets the chance.
Until then you can use LibreCAD to view your DXF file.
archang
Post by archang »
I can use LibreCAD to view the dxf file in Ubuntu, but i can not use AutoCAD、BricsCAD、DWGeditor、DraftSight to view the dxf file in Windows.
It seems to have a problem about exporting.
yorik
Post by yorik »
Indeed there seems to be a problem at export... issue #2177
archang
Post by archang »
Another problem: after export dxf file, the hidden lines is missing. (use LibreCAD to view)
archang
Post by archang »
Enlarged isometric view, there are some incorrect graphics. (red circle place)
