[merged] PR #4118 The section cut feature
nic
Re: [merged] PR #4118 The section cut feature
Post by nic »
Thanks for this feature!
Something I would find really cool : being able to preselect the cut using the fast ``view>>clipping plane``, then press a button from it when I'm happy with the cut.
uwestoehr
Post by uwestoehr »
user1234 wrote: Sun Feb 06, 2022 11:56 am Often some Objects are not correct cut. Independent if it is a linked object or not. The question is if this i OCCT
This is a bug in OCC. Because in your second example you gut at 0.000. When I change it too 0.001, the cut is correct.
For your other, more complex example. I don't get any cut at all. Also the trick I want to implement to put the solids to be cut into a Boolean Fragments instead of a compound fails. It seems the reason is also here OCC. Because hen I omit Body008 and Array002, then I get at least with Boolean Fragments a cut.
So unless someone knows how to cut it right using OCC, I have no idea how to improve the situation.
What is your OCC version? I have OFF 7.5.3 and maybe OCC 7.6 is better.
user1234
Post by user1234 »
uwestoehr wrote: Tue Feb 15, 2022 4:40 am What is your OCC version? I have OFF 7.5.3 and maybe OCC 7.6 is better.
7.6.0. Will uptade the next days to 7.6.1 (which will not solve the issue).
Greetings
user1234
NewJoker
Post by NewJoker »
Is there a way to make it work with assemblies, at least simple ones like the example below ?
persistent cut assy.png (60.77 KiB) Viewed 4164 times
uwestoehr
Post by uwestoehr »
NewJoker wrote: Fri Mar 04, 2022 9:24 am Is there a way to make it work with assemblies, at least simple ones like the example below ?
The limitation for now is that parts touching each other cannot be cut. I plan to work on an option to allow this. But since FreeCAD 0.20 reached the feature freeze, this will not happen soon.
NewJoker
Post by NewJoker »
uwestoehr wrote: Sat Mar 05, 2022 9:21 pm I plan to work on an option to allow this.
It would be great. I only managed to correctly cut this assembly when I used Part Union on it. But then the edges between the parts are lost:
uwestoehr
Post by uwestoehr »
Here is a description of the feature: https://wiki.freecadweb.org/Part_SectionCut
NewJoker
Post by NewJoker »
uwestoehr wrote: Sun Mar 06, 2022 5:10 am Here is a description of the feature: https://wiki.freecadweb.org/Part_SectionCut
Great wiki article, thanks for sharing it. However, the article says that only intersecting parts are not cut. Shouldn’t it say that touching parts (with zero clearance) are not cut too ? In my example, there were no interferences, at least intentional ones. Unless even minimal penetration due to inaccuracy is sufficient for the cut to not work.
Also, if it’s a bug in OCC then maybe we could report it to let the OCC devs know. There’s a chance that they will fix it in the future.
NewJoker wrote: Sat Mar 05, 2022 10:51 pm But then the edges between the parts are lost:
The edges remain if you omit refining.
NewJoker
Post by NewJoker »
chrisb wrote: Sun Mar 06, 2022 9:58 am The edges remain if you omit refining.
Refine is already set to false for both Fusion and SectionCutX:
It seems to affect only the external edges.
