[PR #3965] Sketcher: Merged constraint selection fix.
Bei3lay
Post by Bei3lay »
This problem is in some way similar to the one I already solved before https://forum.freecadweb.org/viewtopic.php?f=17&t=50862. Under certain conditions constraints can't be selected from the merged constraint icons. It happens independent of zoom when sketch is not in XY plane. The reason is that icon position is given in sketcher coordinates but method getCoordsOnSketchPlane is used to project point given in global coordinates to the sketch plane. So it makes no sense to use sketcher coordinates with it. To fix it I manually map sketcher coordinates to global by applying the same rotation and translation as the sketch. Global coordinates are required in order to project point to the screen.
git commit 4516547c8743e44b08441a924f9220efb8b4cd14
PR: https://github.com/FreeCAD/FreeCAD/pull/3965
Re: [PR #3965] Sketcher: Merged constraint selection fix.
Please add PR link in the OP as well, thanks ;)
I'm eager to see this in master and see how it works on the Mac.
abdullah
Post by abdullah »
chrisb wrote: Fri Oct 16, 2020 6:11 pm I'm eager to see this in master and see how it works on the Mac.
It works good on Linux. In the example I tried in XZ plane the selection was unusable without this fix.
