[Merged] [PR #3822] Strange behavior of copyObject
carlopav
Post by carlopav »
If App.ActiveDocument.copyObject(obj) is used on an App::Part, all the Grouped objects appear in the 2 parts at the same time.
Create an App::Part;
Create another object (Part::Cube for example) and move it inside the App::Part;
Use Draft Move with copy enabled to copy the Part object (or the python console with App.ActiveDocument.copyObject(obj));
Result:
Part001
  └ Origin001
  └ Cube001
Part002
  └ Origin002
  └ Cube001
The cube is inside 2 different Part objects... I didnt' think this could be possible...
Version: 0.19.22284 (Git)
Hash: bf1e8e48389f5e9e25bd77b67fe98da4213e797c
Python version: 3.6.8
Qt version: 5.12.1
Locale: Italian/Italy (it_IT)
Reason: Added [Merged]
Re: Strange behavior of copyObject
Moved from Developer forum.
DeepSOIC
Post by DeepSOIC »
I can confirm. Furthermore, i can achieve the same result with duplication dialog (which is a new thing to me actually, I didn't notice when did it appear).
The single-container rule was thought to be necessary when instance objects and crocc-cs links were in planning stage. But realthunder has implemented it all differently, so technically I think the single-container rule is not really needed anymore.
Version: 0.19.18234 (Git)
Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb
Qt version: 5.12.1
IIRC there is a function returning the placement in the global coordinate system. What does it yield for the cube, if it appears in two positions?
DeepSOIC
Post by DeepSOIC »
chrisb wrote: Tue Aug 25, 2020 10:53 pm IIRC there is a function returning the placement in the global coordinate system. What does it yield for the cube, if it appears in two positions?
For me, it returned the position of cube in Part (and Part001 was apparently ignored)
Part-o-magic goes crazy and is stuck with "container tree is not a tree" error message...
I would also expect visibility automation in Sketcher breaking if a sketch is in two places, as I coded it with single-container assumption too... i think...
carlopav
Post by carlopav »
realthunder wrote: Ping
I do not think this is the intended behaviour: an object should be in 2 different positions just if it has a link nested into the tree, or if if is linked, not if it's simply contained by 2 different parts... Is it?
DeepSOIC wrote: Wed Aug 26, 2020 1:00 am For me, it returned the position of cube in Part (and Part001 was apparently ignored)
Users can of course just not do this and avoid troubles, but to me it seems to point to an unclean concept.
realthunder
Post by realthunder »
Just check out the doc string of copyObject(). There are two additional parameters letting you control the behavior. I did modified this function, but the behavior is kept the same before the big merge, i.e. copy without duplicating the dependency.
Same purpose for the object copy dialog. Because of App::Link, there are many possibilities on what depending objects the user want or do not want to copy.
realthunder
I have submitted a PR to throw error in case of copy GeoFeatureGroup/OriginGroup/Part without dependency.
carlopav
Post by carlopav »
I'll check out the doc string of copyObject(). perhaps some different parameters suits better the Draft move with copy usecase.
realthunder wrote: Wed Aug 26, 2020 8:38 am I have submitted a PR to throw error in case of copy GeoFeatureGroup/OriginGroup/Part without dependency.
That was quick! Thanks!
