PR #3748 allow multiselection on creation of pattern
uwestoehr
Post by uwestoehr »
While designing with FC last week it annoyed me that to get patterns of more than one feature, I am forced to create a pattern using only one feature. Then in a second step I had to add the other features to the pattern.
Today I had a look and enabled that one can select several features on creation of a pattern. So with this PR this is now possible:
screencast
screencast
I tested the feature thoroughly (using several bodies, combination of features etc.) and I think it is stable.
Re: PR #3748 allow multiselection on creation of pattern
Very helpful! Thanks.
In rare cases a reordering is necessary. Would it be possible to include? If not as workaround the old mechanism can be used, of course.
uwestoehr
Post by uwestoehr »
chrisb wrote: Mon Jul 27, 2020 3:38 am In rare cases a reordering is necessary. Would it be possible to include?
What do you mean? If you have e.g. 2 features within a pattern, you can reorder them and the patterns keeps stable.
uwestoehr wrote: Mon Jul 27, 2020 10:02 am What do you mean? If you have e.g. 2 features within a pattern, you can reorder them and the patterns keeps stable.
The stability of the pattern is completely out of the range of my thought. I was rather thinking about buttons "Move up", "Move down" which would move a selected feature up or down the list.
The order of the features can be significant.
uwestoehr
Post by uwestoehr »
chrisb wrote: Mon Jul 27, 2020 9:46 pm The stability of the pattern is completely out of the range of my thought....
Do you think so or you have tested this? A testcase would be nice to have. You can create one since my patch does not introduce the multifeature patterning, it just updates the UI that you can do it directly without the need of creating the pattern first then adding more features to it.
I tested the feature order and cannot see any difference on how the features in the pattern are ordered. To break the pattern, you could at first create a pattern and then move one if its features behind the pattern. Then you will get of course an error.
I'm afraid I haven't made myself clear. A testcase should help, but it may have to wait until tonight.
Here is the example (didn't have access to FreeCAD sooner). I have a Cube, a padded circle and a rectangular pocket:
Snip macro screenshot-a53ec2.png (1.91 KiB) Viewed 10942 times
Making a polar pattern with Pad before Pocket:
Snip macro screenshot-c772bc.png (2.85 KiB) Viewed 10940 times
And here with Pocket before Pad:
Snip macro screenshot-6f57fc.png (3.02 KiB) Viewed 10942 times
The version with Pad before Pocket is attached.
pad_before_pocket.FCStd
(22.08 KiB) Downloaded 176 times
uwestoehr wrote: Mon Jul 27, 2020 10:02 am While designing with FC last week it annoyed me that to get patterns of more than one feature, I am forced to create a pattern using only one feature.
Part of your PR is this commit: https://github.com/FreeCAD/FreeCAD/pull ... 68f133d0ea
What's the point about it? The commit message is "Merge branch 'master' of github.com:FreeCAD/FreeCAD into PD-patterning". Apparently it's not something you developed but the code is not part of master either. So, where does it come from?
And according to your description the problem is/was a pure GUI thing so I wouldn't expect any changes on feature level.
vocx
Post by vocx »
wmayer wrote: Thu Jul 30, 2020 8:17 am ...
What's the point about it? The commit message is "Merge branch 'master' of github.com:FreeCAD/FreeCAD into PD-patterning"....
I think such messages appear when the developer has internal branches that he merges before opening the pull request. Git merge always seems to create a commit like this, even if it just says "merging this branch to another".
chrisb wrote: Tue Jul 28, 2020 6:33 am I'm afraid I haven't made myself clear. A testcase should help, but it may have to wait until tonight.
With git commit 94ca4388e you can move the items directly with the mouse.
