PR #2475: Expression syntax extension
Re: PR #2475: Expression syntax extension
git commit 44354b808be (and possibly earlier commits) cause some memory leaks because instances of Py classes are created on the heap and passed as argument to Py::Object() so that the reference counter is incremented twice.
Example:
Create a sphere and try this code snippet:
o=App.ActiveDocument.ActiveObject
o.evalExpression("minvert(Sphere.Shape.Placement)")
When running it in debug mode set a breakpoint to the constructor and destructor of PlacmentPy. The constructor is accessed twice but the destructor only once.
vocx
Post by vocx »
wmayer wrote: Mon Oct 07, 2019 10:14 pm ...The constructor is accessed twice but the destructor only once.
I don't know if this is related but I've noticed a problem that makes me think of this. Ocassionaly when creating an object from a base object, two objects are created at once, like if the command was given twice. Do you think this is related? It doesn't seem to be a big problem other than you have to delete the second object.
I saw this when I was using the Dodo workbench (external workbenches) that is used to create pipe and frame objects. For example, I would place a wire, then select it, and hit a button to create a pipe. Instead of getting one pipe, I would get two. Of course, the problem could be in the Dodo workbench itself, but I wonder if this is not something more people have experienced.
realthunder
Post by realthunder »
wmayer wrote: Mon Oct 07, 2019 10:14 pm git commit 44354b808be (and possibly earlier commits) cause some memory leaks because instances of Py classes are created on the heap and passed as argument to Py::Object() so that the reference counter is incremented twice.
Oops, this is not the first time I made this mistake. I searched around and fixed some similar ones. PR is here.
vocx wrote: Mon Oct 07, 2019 10:38 pm
If I understand this right then it's a different thing. What I am talking about is to handle the reference counter of Python objects where it happens that the counter is incremented one time too often so that when releasing it to the interpreter it will never become zero and thus the allocated memory won't be freed any more.
realthunder wrote: Tue Oct 08, 2019 1:23 am
Thanks!
DeepSOIC wrote: Mon Sep 30, 2019 2:29 pm
wmayer wrote: Mon Sep 30, 2019 12:22 pm
This is true for numbers (1/X = X^-1), but there is a rigorous mathematical notion behind it, that allows to define X^-3 or X^(1/2), but for matrices or Placements, what would mean :
On Wikipedia you can find some information for square roots of a matrix but it's only well-defined for positive-definite matrices while for arbitrary matrices it causes ambiguities. But what when using 1/3 as exponent instead? Here I couldn't find a valid definition. So, a power function for arbitrary exponents makes probably not much sense (especially not in a CAD program) and it should be limited to integers only as done by the current implementation.
I've been actually wanting this arbitrary exponent as a way to interpolate between placements.
You don't have to define, what ^(1/3) means, as 1/3 can't be precisely represented by a float anyway. A fractional part of float is a sum of fractions:
bit1*1/2 + bit2*1/4 + bit3*1/8 +...
Power-of-two fractional powers can be easily calculated by multiplying M^(1/2) by itself.
Do you have any concrete ideas/suggestions how to implement this? You may know the function "slerp" for quaternions which is about this but the idea could be extended for placements. I wonder whether we should use a real function name for this instead of using the pow() function.
DeepSOIC
Post by DeepSOIC »
Given scipy's matrix square rooting function (scipy.linalg.sqrtm), I can give it a shot...
DeepSOIC
Post by DeepSOIC »
Bad news.
square root of a placement matrix is not a placement matrix.
>>> rtm # the square root of matrix of a placement with some translation and some rotation
Matrix ((0.935334,0.241336,0.258664,7.09003),(0.258664,0.965346,0.0346543,8.62005),(0.241336,0.0993202,0.965346,3.10023),(0,0,0,1))
>>> rtplm.toMatrix() # if matrix survives being converted into placement, we are good
Matrix ((0.999922,-0.00851867,0.0088085,7.09003),(0.0088085,0.99942,-0.0322941,8.62005),(-0.00851867,0.0323718,0.99942,3.10023),(0,0,0,1))
>>> #no, matrix of placement is different. Bummer!
Have you ever heard of dual quaternions? For quaternions we have a spherical linear interpolation called slerp and when searching for an extension to also handle translation I stumbled across dual quaternions: https://community.khronos.org/t/dual-qu ... lerp/72496
This references an interesting paper about the math and some source code:
http://www.xbdev.net/misc_demos/demos/d ... /paper.pdf
That's exactly what we need.
OCCT provides the class NCollection_Lerp<gp_Trsf> (see header gp_TrsfNLerp.hxx) which handles rotation and translation independently but that may cause some unnatural movements.
DeepSOIC
Post by DeepSOIC »
wmayer wrote: Tue Oct 08, 2019 8:22 pm Have you ever heard of dual quaternions?
Nope :roll:
wmayer wrote: Tue Oct 08, 2019 8:22 pm This references an interesting paper about the math and some source code:
reading,,,
