PR #2475: Expression syntax extension
Re: PR #2475: Expression syntax extension
DeepSOIC wrote: Tue Oct 08, 2019 7:15 pm Bad news.
square root of a placement matrix is not a placement matrix.
As said above the square root of an arbitrary matrix is ambiguous and it's hard to say what the scipy implementation actually does.
But:
When you have placement with rotation R and translation t and apply it twice, i.e. get the square you have:
y = R * (R * x + t) + t
y = R * (R * x) + R * t + t
y= (R * R) * x + (R + I) * t
this means you have the rotation Q = R * R and the translation s = (R + I) * t.
Now if you consider a placement with rotation Q and translation s you can easily get the square root of Q (by doing only the half rotation) but for the translation part you have to compute t = (R + I)^-1 * s and the question is if this matrix is always invertible.
Example:
import math
# arbitrarily rotate the object
p=App.ActiveDocument.ActiveObject.Placement
p.Base # Vector (-4.642491320876232, 2.744713842009025, 9.827212698728683)
p.Rotation.Q # (0.14145656219842426, -0.6950597415393837, -0.4084936490538904, 0.5744692640906436)
q=App.Rotation(p.Rotation.Axis, math.degrees(p.Rotation.Angle/2))
# compare the axes and angles
p.Rotation.Axis
q.Axis
p.Rotation.Angle
q.Angle # = p.Rotation.Angle/2
# get q as matrix
r=q.toMatrix()
r.determinant() # = 1.0 ok
m = r + App.Matrix() # (R + I) from above
m_inv = m.inverse()
s = p.Base
t = m_inv.multVec(s)
p_root = App.Placement(t, q)
# p_root * p_root gives the same as p
p_root.multiply(p_root) # Placement [Pos=(-4.64249,2.74471,9.82721), Yaw-Pitch-Roll=(-114.246,-43.0795,90.4892)]
p # Placement [Pos=(-4.64249,2.74471,9.82721), Yaw-Pitch-Roll=(-114.246,-43.0795,90.4892)]
# the same for their matrix representations
p.toMatrix()
p_root.toMatrix().multiply(p_root.toMatrix())
So, it's possible at least in this case to get the square root of a placement or matrix but the question is whether R + I is always invertible.
DeepSOIC
Post by DeepSOIC »
wmayer wrote: Tue Oct 08, 2019 8:22 pm This references an interesting paper about the math and some source code:
http://www.xbdev.net/misc_demos/demos/d ... /paper.pdf
That's exactly what we need.
Well, I have read it, and mostly understood it. I think I feel like trying to implement it in FreeCAD. Maybe prototype it in python first.
BTW, I noticed funny correlations between 'dual numbers' thing and "DeriVector2" I've made up for sketcher solver.
yorik
Post by yorik »
These high-level math discussions are cool :)
DeepSOIC
Post by DeepSOIC »
BTW, I've prototyped it in python, and will post a demo in a separate thread. That thing is definitely working.
toralf
Post by toralf »
Could you please provide a link to the thread? I could not find it. But maybe you have not posted it yet.
DeepSOIC
Post by DeepSOIC »
toralf wrote: Thu Oct 10, 2019 7:48 pm Could you please provide a link to the thread? I could not find it. But maybe you have not posted it yet.
I haven't :oops: jumped straight to implementing it into FC.
toralf
Post by toralf »
Ok, don’t worry. Go ahead.
DeepSOIC
Post by DeepSOIC »
Here! https://forum.freecadweb.org/viewtopic. ... 54#p340354
Small addition: I found an example where R + I is not invertible. For every rotation with an angle of 180 deg the determinant of R + I becomes zero and thus is not invertible.
Here is short example to demonstrate the new sclerp() function of the placement:
def animate(box, p1, p2, p3, steps=100):
  for i in range(steps):
    t=(i+1)/steps
    p=p1.sclerp(t,p2)
    box.Placement=p
    Gui.updateGui()
    t=(i+1)/steps
    p=p2.sclerp(t,p3)
    box.Placement=p
    Gui.updateGui()
box=App.ActiveDocument.Box
p1=box.Placement
p2=box.Placement # after changing manually
p3=box.Placement # after changing manually
animate(box, p1, p2, p3, 100)
p1, p2 and p3 define three different placements and with this script you can nicely see how the interpolation works.
