Page 6 of 20
Re: FreeCAD Nodes (renamed from fc_nodes)
Posted: Thu Nov 24, 2022 9:53 am
by j8sr0230
Hi friends,
it took me a while, but the Voronoi on Solid node is now available. It generates a Voronoi diagram not on a mesh but on a real BRep solid and produces either clean solids or shells. It supports the modes solid voronoi cells (0), inverse solid voronoi cells (1), voronoi shells (2) and inverse voronoi shells (3), see figure. Enclosed you will also find a small demo file for an easy entry. Have fun with it!
- Voronoi on Solid
- nodes_voronoi_on_solids.PNG (698.65 KiB) Viewed 13327 times
Posted: Thu Nov 24, 2022 2:18 pm
by ncadoret
j8sr0230 wrote: ↑Wed Nov 23, 2022 9:38 pm
IT IS ALIVE!!! The new
Voronoi on Solid node for FreeCAD Nodes is
coming soon
Now you have my attention !
I am very interested in creating Voronoï type structures inside solids and was struggling to create a macro for it. I'm sure with that node I will be able to get the results I want much quicker.
Need to find the time to play with it but thank you for your work !
Posted: Fri Nov 25, 2022 10:12 am
by j8sr0230
Hi friends,
just in time for Black Friday there are lots of new nodes. I have just published the nodes
Extrude, Vector Math, Vector Length and Surface Center. Attached is a nice application example where Voronoi cells are extruded in the Z direction depending on their distance from the red marked point. Have fun with it
- Extrusion_viewport
- extrusion_node.PNG (192.82 KiB) Viewed 13168 times
- Extrusion_node_graph
- extrusion_node_graph.PNG (150.69 KiB) Viewed 13168 times
Posted: Fri Nov 25, 2022 10:33 am
by -alex-
Models done with this WB are impressive!
As a simple user I hope to be skilled enought someday to use it.
Thanks for your efforts
Posted: Fri Nov 25, 2022 10:48 am
by j8sr0230
-alex- wrote: ↑Fri Nov 25, 2022 10:33 am
After there is a reasonable roundstock of nodes and a stable framework, I will start a Youtube series to promote the Workbench and node-based modeling with FreeCAD. My intention is to pick up all users with small follow along videos. But it will take a bit more time i think
By the way, the node graph I have shown above is complete and does not need any further dependencies. That means, if you wire everything as shown, you will also get the displayed parametric extrusion. Just dare
Posted: Fri Nov 25, 2022 11:40 am
by -alex-
j8sr0230 wrote: ↑Fri Nov 25, 2022 10:48 am
That would be great
FC motto: it's done when it's done
Just dare
You're right
Posted: Mon Nov 28, 2022 8:08 am
by j8sr0230
Transform Nodes for FreeCAD Nodes
With the latest update the transform nodes Rotate, Translate and Uniform Scale are now available. All support multi input for all sockets and array broadcasting. Here you can see a simple demo for the Rotate node.
- Rotate node demo
- cube_rotation.gif (935.75 KiB) Viewed 12534 times
Posted: Mon Nov 28, 2022 10:43 am
by j8sr0230
And the new
Evaluate Srf node in action:
- Evaluate Srf node
- nodes_evaluate_surface.gif (533.13 KiB) Viewed 12494 times
Posted: Mon Nov 28, 2022 1:45 pm
by j8sr0230
The new
Align node allows you to align shapes to vectors. In the following example, I determine the surface normal of a sphere at selected points and align a prism to it. The duplication of the prism to each point of interest is done automatically by array broadcasting.
- Align node
- nodes_align_shape.gif (894.11 KiB) Viewed 12382 times
Posted: Mon Nov 28, 2022 7:58 pm
by Kunda1
Unbelievable progress! :mindblown:
