Heating system source station and substation
guido68
Post by guido68 »
I would like to share two examples of how I used Arch and Dodo WB workbenches.
Source station
Source station
Substation
Substation
Guido
https://drive.google.com/drive/folders/ ... sp=sharing
Version: 0.19.24267 +148 (Git)
Branch: Branch_0.19.4
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
intufreecad
Re: Heating system source station and substation
Post by intufreecad »
Hi there
I Work in heating planing too.
Very well done that work. You know how to simplify non essetial parts. I love it.
I experimented with Dodo too. Dodo and Arch WB Seem to play well together for you. Do you have a sample file to share?
Marcel a freecad lover
NewJoker
Post by NewJoker »
Looks really great and professional. Which software was used for the visualization ?
intufreecad wrote: Thu Jul 21, 2022 3:33 am Do you have a sample file to share?
Guido shared a link to his Google Drive folder with FreeCAD files with these models.
guido68
Post by guido68 »
intufreecad wrote: Thu Jul 21, 2022 3:33 am Very well done that work. You know how to simplify non essetial parts. I love it.
Yep :D, I have been following this concept since I started to draw 2D layouts. Most of the times the step (or other formats) models that producers share on their sites are too much complex for an easy use. For example if you need to insert a circulator pump in a model, like that I drew, the detail of bolts, screws or a very detailed circulator casing are unuseful, you need fluid inlet and outlet diameter, shape and dimensions of an essential casing, that's it.
guido68
Post by guido68 »
NewJoker wrote: Thu Jul 21, 2022 7:28 am Looks really great and professional. Which software was used for the visualization ?
I used FreeCAD's Raytracing workbench to create the .pov file for POV-Ray and then I rendered the model with the following command line:
"C:\Program Files\POV-Ray\v3.7\bin\pvengine64.exe" file_name.pov +W1280 +H1024 +AM2 +A
NewJoker
Post by NewJoker »
guido68 wrote: Thu Jul 21, 2022 8:10 am I used FreeCAD's Raytracing workbench to create the .pov file for POV-Ray and then I rendered the model with the following command line:
Cool, thank you for clarifying. I thought that it was rendered in Blender or something like that.
paullee
Post by paullee »
Looks great indeed !
