Zombie project, or small conversion FC16->FC20
wieszak17
Re: Zombie project, or small conversion FC16->FC20
Post by wieszak17 »
And now for something completely different... I mean next update is for construction group 06 - boiler:
-hinges for smokebox door:
https://para.zonk.pl/Ol49forum/fcstd/06/5.33-0-1.fcstd
-some of outer parts of boiler, elements for firebox will be in another file, and they are troblesome...
https://para.zonk.pl/Ol49forum/fcstd/06/P610-1-0.fcstd
-bolts and connectors for above elements
https://para.zonk.pl/Ol49forum/fcstd/06/P611-1-0.fcstd
-mud collector(?):
https://para.zonk.pl/Ol49forum/fcstd/06/P625-1-0.fcstd
-steam dome:
https://para.zonk.pl/Ol49forum/fcstd/06/P626-1-0.fcstd
-water separator:
https://para.zonk.pl/Ol49forum/fcstd/06/P627-1-0.fcstd
and current boiler assembly:
wieszak17
Post by wieszak17 »
Todays, smaller update is again about group 02. Progres here will slow down, most of old finished files are converted in thus group. Besides two quite complicated ones there are few which i didn't finished then, so i will more time to convert and finish them. So:
-equalizers between third and fourth axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P282-1-0.fcstd
-equlizers between fourth and fifth axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P283-1-0.fcstd
-spring hangers, gibs and clips:
https://para.zonk.pl/Ol49forum/fcstd/02/P286-1-0.fcstd
and assembly view:
bambuko
Post by bambuko »
wieszak17 wrote: Wed Jun 01, 2022 5:18 pm -steam dome:
http://para.zonk.pl/Ol49forum/fcstd/06/P626-1-0.fcstd
@wieszak17 I have opened this file (to see how you model things and perhaps learn from you as well ;) ) and I am puzzled how you create (for example) the nuts?
Can you explain, please?
Screenshot from 2022-06-04 10.13.49.png (125.08 KiB) Viewed 2534 times
wieszak17
Post by wieszak17 »
I just made them once in every size and simple copy them into projects. Here you are:
http://para.zonk.pl/nakretki.fcstd - FC16 (FC15?) file, never converted.
Bolts are nearly the same, separate file with common sizes - i'm only changing last Pad to set length of bolt, then simple copy it to project:
http://para.zonk.pl/srubazwykla.fcstd
I'm not copying Revolutions/Pad/Pockets from this files for one reason - it would greatly slow down loading project file without giving any merit - these are standard things, no need to edit them.
bambuko
Post by bambuko »
wieszak17 wrote: Sat Jun 04, 2022 10:20 am ... and simple copy them into projects...
an interesting (and different) way of doing things ;)
understand, thank you.
BTW there is something strange (at least to me) in your nut (nakretki) file.
How is it possible to have pockets and revolution without body container?
Why do you use "Group" instead?
Screenshot from 2022-06-04 11.34.07.png (69.98 KiB) Viewed 2494 times
wieszak17
Post by wieszak17 »
There was no body/part element when that file was created - it is FC16/15 file. So Group was only way to somehow organize objects. I have never converted that file because i'm only using refined shapes from it. Bolts was the same, but because i need to change Pad i was forced to convert it to Body/Part.
bambuko
Post by bambuko »
wieszak17 wrote: Sat Jun 04, 2022 10:51 am There was no body/part element when that file was created - it is FC16/15 file.
that's well before my time ;)
thank you for explanation :idea:
wieszak17
Post by wieszak17 »
Time for next update, today still group 02.
-coupler:
https://para.zonk.pl/Ol49forum/fcstd/02/10.31.fcstd
-connector between frames, with guides for suspension of fifth axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P232-1-0.fcstd
-support for equalizer between first and second axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P236-1-0.fcstd
-supports for equalizer between fourth and fifth axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P238-1-0.fcstd
-support and steps for smokebox:
https://para.zonk.pl/Ol49forum/fcstd/02/P292-1-0.fcstd
-covers for springs for first axle:
https://para.zonk.pl/Ol49forum/fcstd/02/P2921-1-0.fcstd
And assembly view:
KurtF
Post by KurtF »
Hi Wieszak, I've been enjoying your project. But I noticed that all your bolts are threadless. May I offer assistance? ThreadMaker Macro
May whatever Higher Power you believe in bless the Ukrainians. They are a decent people who never hurt anybody.
M4x
Post by M4x »
It's good practice to not model the threads. The reason is that it would make the 3D model unnecessary complex / harder to calculate / recompute and render.
