Simple statue
Agentkayy
Simple statue
Post by Agentkayy »
Description: Water closet, most of us pray it everyday
Usage: To dump our loads
OS: Microsoft Windows 10
Freecad version: 0.19.4
Notes: All steps is in part designer workbench, all unit are in meters(m) unless mentioned, sorry USA, Liberia and Burma.
How I done it:
  1. Bowl
    1. Create an additive box with
      • Length of 0.365
      • Width of 0.68
      • Height of 0.415
    2. Create a subtractive box with
      • Length of 0.365
      • Width of 0.5
      • Height of 0.015
      • Reference at top of the previous box (box)
      • Y = 0.18
      • Z = -0.015
    3. Create a datum line at
      • X = 0.1825
      • Y = 0.4975
    4. Create a sketch at X/Z plane
      • Attachment Offset
        • X = 0
        • Y = 0.4975
        • Z = 0
      • Create an edge linked to an external geometry with the bottom line of the subtractive box (box001)
      • Create a horizontal line at X-axis with a length of 0.0325
      • Create an arc with
        • Radius of 0.06
        • Angle of ½π rad or 90 deg
        • Radius of 0.1825
      • Fix the center of longer radius arc onto the external geometry line
      • Fix an end of the longer radius arc onto left end of the external geometry line
      • Fix the other end of the longer radius arc onto one of the end of the shorter radius arc
      • Create a tangent constrain with the 2 arcs
      • Connect the other end of the shorter radius arc with a line to the horizontal line
      • Create a tangent constrain with the new line and the smaller arc
      • Create a vertical line that connect the horizontal line and the end of longer radius arc that fixed onto external geometry line
    5. Groove the sketch (Sketch) with
      • Axis at the datum line(DatumLine)
      • Angle of π rad or 180 deg
      • ✅Check reversed
    6. Create another sketch on left side surface
      • Create an edge linked to an external geometry with top left point of the additive box (box)
      • Create an edge linked to an external geometry with bottom left point of the additive box (box)
        • Radius of 0.1
      • Create a vertical constrain with one of the end the arc and its center
      • Create a horizontal constrain with the other end of the arc and its center
      • Connect the top end of the arc to its center with a vertical line
      • Create a vertical line that connect the arc's center and the bottom left point of the additive box (box)
      • Create a horizontal line starting from the bottom left point of the additive box (box)
      • Create another vertical line that connect the rear end of the arc and the other end of the horizontal line
      • Fix the vertical distance between two points or line ends with
        • top left point of the additive box (box)
        • the top end of the arc
        • Distance of 0.08
    7. Pocket the sketch above (Sketch001)
      • Type = To first
      • Offset = 0
    8. Create pocket with
      • The surface created by grooving the first sketch (Sketch) (Face 5)
      • The other surface surface created by the groove (Face 14)
  2. Tank
      • Length of 0.365
      • Width of 0.18
      • Height of 0.31
      • Reference at the higher top face of the bowl (Pocket002:Face2)
      • X = 0
      • Y = 0.18
  3. Tank lid
      • Length of 0.38
      • Width of 0.2
      • Height of 0.035
      • Reference at the top of the tank
      • X = 0.0075
      • Y = 0.01
      • Z = 0
  4. Bowl lid
    1. Create an additive cylinder with
      • Radius of 0.1825
      • Height of 0.035
      • Reference at lower top face of the bowl (Pocket002:Face7)
      • X = 0.1825
      • Y = 0.3175
      • Z = 0
    2. Create an additive box with
      • Length of 0.365
      • Width of 0.24
      • Height of 0.035
      • X = 0
      • Y = 0.0775
      • Z = 0
water_closet.FCStd
(91.15 KiB) Downloaded 49 times
KurtF
Re: Simple statue
Post by KurtF »
Priceless! Lol. Please visit my Showcase Entry (ThreadMaker). It may help with the plumbing. :-)
May whatever Higher Power you believe in bless the Ukrainians. They are a decent people who never hurt anybody.
Agentkayy
Re: Simple statue
Post by Agentkayy »
Unfortunately I don't know the internal dimensions and I don't have spares that I can measure it nor do I have proper tool.
This model is only for Interior design purpose, need to find a more detailed tech draw or a spare real model. :lol:
Re: Simple statue
Thanks for showing with such a detailed description (can be used as a toilutorial :lol: ).
KurtF
Re: Simple statue
Post by KurtF »
Do forum rules allow me to ask if this is the Russian Statue of Liberty?
Agentkayy
Re: Simple statue
Post by Agentkayy »
chrisb wrote: Fri Apr 22, 2022 4:31 pm Thanks for showing with such a detailed description (can be used a toilutorial :lol: ).
Assembly language format, feel free to post it to FreeCAD wiki tutorials.
PS I found out most tutorial isn't based on everyday objects.
Shalmeneser
Re: Simple statue
Post by Shalmeneser »
For such a toilet, an other flow is to use a pipe :
Capture d’écran 2022-04-22 190837.jpg (45.42 KiB) Viewed 2351 times
water_closet_SHALM.FCStd
(43.28 KiB) Downloaded 23 times
Re: Simple statue
KurtF wrote: Fri Apr 22, 2022 4:44 pm Do forum rules allow me to ask if this is the Russian Statue of Liberty?
This would be very funny if it wasn't so damn serious!
Agentkayy
Re: Simple statue
Post by Agentkayy »
Rusky gopnik version coming right up, stay tuned.
KurtF
Re: Simple statue
Post by KurtF »
chrisb wrote: Fri Apr 22, 2022 5:50 pm This would be very funny if it wasn't so damn serious!
I feel you.
Agentkayy wrote: Fri Apr 22, 2022 5:55 pm Rusky gopnik version coming right up, stay tuned.
May I interest you in a Reverse-Auto-Plunger? It is easily sized to fit the center, bottom of any toilet bowl. Such an important statue should be self-cleaning.
RSL Reverse Auto Plunger.jpg (35.22 KiB) Viewed 2288 times
(Plunger by ThreadMaker)
Edit: Ok, ok. Sorry for shamelessly plugging my own showcase project in your project thread. Also sorry for using the phrase 'shamelessly plugging' in the context of this thread. :-)
