XLR connector
NewJoker
XLR connector
Post by NewJoker »
I followed this tutorial meant for Inventor: https://www.youtube.com/watch?v=lVJm9QLNHtY
and created the model presented here:
XLR connector.JPG (52.75 KiB) Viewed 1958 times
I used 0.20 (details below) and Link branch (just for the visualization).
Here are some notes:
- I really like the versatility of tools for coloring, especially the Pick Screen Color option
- I gave up on fillets for that middle section of the connector (they wouldn't improve the model's appearance significantly anyway)
- I had to mix Part Design and Part workbenches because of that complex cutout with triangular embossing - it was necessary to wrap the sketches on cylindrical faces and I used Part ProjectionOnSurface which worked really nice here
- when I tried to use PD workbench during the later steps of the modeling, the cutout disappeared and some glitches occurred so I sticked to Part wb for the remaining stages of the design
I attached the file below. I will be grateful for any tips on how this could be modeled in a better way.
XLR connector from Inventor 2.FCStd
(172.54 KiB) Downloaded 63 times
Version: 0.20.28717 (Git)
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Polish/Poland (pl_PL)
Shalmeneser
Re: XLR connector
Post by Shalmeneser »
Do not sketch upon face : TNP (same for DatumPlane).
I don't understand everything of your file.
XLR connector from Inventor 2_SHALM.FCStd
(198.73 KiB) Downloaded 44 times
Capture d’écran 2022-04-18 223434.jpg (56.96 KiB) Viewed 1907 times
NewJoker
Re: XLR connector
Post by NewJoker »
Shalmeneser wrote: Mon Apr 18, 2022 8:39 pm Do not sketch upon face : TNP (same for DatumPlane).
Yeah, I know. I just assume no need for modifications in my simple models. Hopefully, this approach will be valid in the next version.
Shalmeneser wrote: Mon Apr 18, 2022 8:39 pm I don't understand everything of your file.
Well, that cutout required some workarounds and that's what caused the mess in the model tree. There are boolean operations, projected faces and so on.
freedman
Re: XLR connector
Post by freedman »
I didn't want to do the whole connector but here is the PartDesign metal part. I kind of threw it together but it lets you see the pad/pocket process. Using Refine cleans up the feature lines.
conn2.FCStd
(184.48 KiB) Downloaded 49 times
NewJoker
Re: XLR connector
Post by NewJoker »
freedman wrote: Tue Apr 19, 2022 12:02 am I didn't want to do the whole connector but here is the PartDesign metal part.
Thanks, that's also interesting way to realize this cutout.
