IKEA style assembly instructions
henkjan_nl
Post by henkjan_nl »
I used FreeCAD and Inkscape together to make IKEA style assembly instructions for one of my projects. For those interested: I documented the way I made the instructions on my Github at: https://github.com/henkjannl/TravelWall ... /Readme.md. All files used are also in the same GitHub. Enjoy!
HenkJan
obelisk79
Re: IKEA style assembly instructions
Post by obelisk79 »
very nice instructions, easy to follow
NewJoker
Post by NewJoker »
Looks awesome. Thank you for sharing this. I often encounter questions about how to do something like that in commercial CAD software. And now we have a reference showing how to do it in FOSS.
Zolko
Post by Zolko »
henkjan_nl wrote: Mon Mar 28, 2022 6:04 pm assembly instructions for one of my projects.
nice, looks like a very thought-out project ... did you think about patenting it ? I'm wondering: the 5-€uro note seems like cut to size rather than bent, as it appears evident from the small 3cmx3cm piece of paper that is bent under the 2-€uro pieces : panel 5 could be improved.
Also, how are the 2-€uro pieces held in place ? What's the purpose of the small papers below them ? If you spend all the notes, do the coins fall out ? Also, what about 50-€uro notes, is the device compatible ? And 100€ ? Questions above questions ...
henkjan_nl
Hi
Sorry for the slow response, I hadn't noticed your reply
The banknotes are indeed folded rather than cut, but the white piece of paper was easier to draw in Inkscape than the banknote
It works for any banknote that is smaller than a credit card when folded
The purpose of the 3x3 cm paper is to prevent the coins making a rattling sound when the device is in your pocket.
Enjoy!
HenkJan
M4x
Post by M4x »
I'm going to have a look at your project when I'm at a computer. But what I can say already: Great idea to document the way you've created the assembly instructions! Thank you very much! We need more of this kind of documentation.
Karema
Post by Karema »
I really hope that there will be a workbench to be able to easily produce assembly instructions. I really miss it.
Nice assembly instructions for that part.:) I make a lot of assembly instructions but have never tried to make them in FreeCAD. Maybe I should try it.
bavariaSHAPE
Post by bavariaSHAPE »
FreeCAD is definitely suitable for the graphics in operating instructions and service manuals. I use FreeCAD almost daily as a technical editor and illustrator. I receive STEP files from the customer, which I import and create an exploded view in FreeCAD. I design missing parts in FreeCAD. Purchased parts are usually obtained from the manufacturer. The finished graphic is created with Inkscape. Both software programs are an ideal complement.
See also an example of mine: https://youtu.be/qIWFRBcY_Ec?si=atTGBaEeNS0sBWVn
… for a happy FreeCAD-World … JM2C …
bavariaSHAPE wrote: Fri Jan 19, 2024 9:16 am FreeCAD is definitely suitable for the graphics in operating instructions and service manuals.
Thanks for sharing. Did you ever try Exploded Assembly addon?
bavariaSHAPE
chrisb wrote: Fri Jan 19, 2024 10:19 am
No, I haven't tried it yet. Thanks again for the tip. I couldn't install it via the addon manager. So I started the download directly from github. I will test it in the near future.
OS: Windows 7 build 7601
Version: 0.21.1.33668 +26 (Git)
Branch: (HEAD detached at 0.21.1)
Hash: f6708547a9bb3f71a4aaade12109f511a72c207c
  * A2plus 0.4.60n
  * Curves 0.6.16
  * ExplodedAssembly
  * SheetMetal 0.3.16
