From FreeCAD To The Real World
Re: From FreeCAD To The Real World
Hi !
Many thanks to FreeCAD developers ! This was fast and easy design with FC & fast cut on small mill but kids were very happy that they could make their own "refrigerator magnets"
cut with protective foil still on: ready decorative refrigerator magnets: Happy New Year !
Check out my designs on https://www.youmagine.com/funkysod/designs, my videos at https://www.youtube.com/user/funkysod
Finally managed to fix my daughter's tent as it was collapsing all the time.
A bit of FreeCAD, over-engineering and 3d printing does the job perfectly.
CNC clutch
hello all !
The issue was a cap on hydraulic tank, fixed with only 2 screws in 2mm thickness steel sheet, lets the rain get into tank
To fix that I chose to increase steel thickness (2mm -> 6mm) and number of screws (2 -> 4). the cap is not weldable, flanged way is chosen.
1 - drawing
2 - FEM analysis
3 - change drawing and select suitable steel
4 - machining, welding, drilling, threading
Well done ! FreeCAD is cool
1 - drawing
2 - FEM analysis
FreeCAD is cool
Hello all,
Let's made a pair of weldable half C clamps (what's this ??? https://www.google.com/search?q=weldabl ... 90&bih=732)
At office I've done with FreeCAD : design, FEM static analysis and drawing (one view in 1:1 scale for free hand cutting)
Material selected : Low alloy, high strength and wear resistant steel HARDOX 400 typical yield strength 1100 MPa, tensile strength 1250 MPa, good values, but still below analysis results.
At workshop I've done : cutting, cleaning, machining and welding.
Last step is painting and taping to have a clean and nice thread.
FreeCAD is cool
The mixer knob on my shower mixer broke completely. Printed this as a replacement part. Works very well and is way cheaper than buying the replacement.
It's a very simple design but perhaps someone gets inspired. Maybe as a beginner exercise in freecad!
- 2021-03-08-082831_1600x900_scrot.png (124.59 KiB) Viewed 6287 times
- shower_knob.FCStd
- (39.46 KiB) Downloaded 129 times
- IMG_20210308_081437.jpg (569.47 KiB) Viewed 6287 times
Hello all !
Today I make a hoist trolley, design with Part & Fastener, FEM analysis, assembly with A2plus and exploded view by Exploded Assembly
Next step : drawing and fabrication.
FreeCAD is cool
Finally, I downsized steel thickness to 6mm, with high strength steel S700.
Below you can see drawings, first test assembly and finished parts.
FreeCAD get the job done.
FreeCAD is cool
