Design for Gikfun 12mmx12mm pushbutton wall pass-through
GameMaker
Post by GameMaker »
Hello friends,
I'm designing and building a custom alarm clock for my son. Arduino inside, with a speaker and DS3231 timing chip with battery backup.
I need buttons on the outside to set time, alarm, etc. I'm using these buttons, which will be along the side of the case.
So I need a way to place the body on the inside, but have the hat stick through the case - and there needs to be a 'backboard' so that when you press the button, it stays in place and registers a press, rather than just sliding into the case.
The trick is, there are some protrusions on the top of the body, so there needs to be a recess in the wall, so you can place the button against it, then slide it down into place.
After a few iterations, I came up with this design.
View from the inside - showing the 'backstop' as well as the pockets that let the button slide down into place:
2021-11-24 09_31_35-FreeCAD 0.19.jpg (35.71 KiB) Viewed 3280 times
From the outside, we need a recess for the button, as well as some room for the hat to 'snap on' to the button switch itself:
2021-11-24 09_34_40-FreeCAD 0.19.jpg (32.7 KiB) Viewed 3280 times
Tried it last night, and works like a charm. Here are some tech drawings I made in case anyone wants to use in their designs:
12mmButtonHolderPassthrough.pdf
(271.85 KiB) Downloaded 85 times
I'm a fairly new maker, very new to FreeCAD, grateful for all constructive critique / suggestions.
[EDIT]: Uploading model:
ButtonHolderTest.FCStd
(118.67 KiB) Downloaded 55 times
Best,
Aaron
Re: Design for Gikfun 12mmx12mm pushbutton wall pass-through
GameMaker wrote: Wed Nov 24, 2021 6:15 pm I'm a fairly new maker, very new to FreeCAD, grateful for all constructive critique / suggestions.
For that you should upload the model.
GameMaker
Post by GameMaker »
Gaah - of course, sorry. First post ever. :)
Edited and added model. Thanks!
I'm a Sketcher guy, so looking especially at sketches: I like that you didn't make your sketches too complicated! Some points you can improve:
Sketch: Look at the document in my footer on how to center rectangles using diagonal points. (In 0.20 you can create them already centered.)
Other sketches: better use Sketch as external reference, not the pad. See topological naming problem.
Sketch008: prefer geometric constraints over dimensions; here: use equality.
