Little experiment with Optics WorkBench, in FREECAD!
Might be a PERFECT BLACK BODY, using a tubular object as lens.
Not a single ray escaping the outer periphery of the tube!!
Shall we name it as BLACK-LENS?
(NEED TO VERIFY WITH REAL EXPERIMENT).
Optics WorkBench - Black_Lens
- Black - Lense.jpeg (57.77 KiB) Viewed 2804 times
Re: Optics WorkBench - Black_Lens
Nice idea but this seems to me to be an effect of a particular ray angle. Also there seems to be a lack of consideration of external surface reflection (as opposed to TIR) by the optics workbench in this example. For example you show a ray off axis getting trapped in the cylinder as for an optical fibre, but rays closer to the central axis should pass straight through with minimum deviation. So I suspect the 'trapped' ray' is a special case for a narrow range of incident rays. I am happy to be proved wrong, of course.
