For the last nine years I have been involved in the restoration to operation of Alaska Railroad #557, an S-160 Consolidation steam locomotive. Of 2,120 that were built during WWII, almost all went to Europe but 12 operated in Alaska in the U.S.A. On and off for the last 35 years I have also been building a 1/8 scale model of an S-160. Two years ago the combination of free 3D modeling software, low cost 3D printers, the availability of affordable castable resins, Youtube videos on using Freecad, and Youtube videos on using printed parts for investment casting caused me to take the plunge and move beyond 2D CAD and fabricating or machining parts from the solid. My newfound knowledge has caused me to completely rethink how I made parts for my locomotive model making them much simpler and allowing detail that I had only dreamed of in the past.
For the full-sized locomotive we needed additional universal joints that are used to extend valve spindles to the handles in the cab. I drew them in Freecad, basing the model on prototype engineering drawings, printed them in castable resin, cast them in silicon bronze, and machined and assembled them for use. Wanting to test the limitations of the process I then used the same 3D model and printed it at 1/4, 1/5, and 1/6 scale and made miniature versions. The filigree valve handle at full size and 1/4 scale were done at the same time. The trunnion and bolts in the smallest universal joints in my hand are #00 machine screw size, which is .047 inch/1.2 mm in diameter. I do this for my own entertainment, but I recently cast and donated an 76 sets of castings for the small universal joints which were sold to benefit the restoration of the full sized locomotive.
Thank you to the developers of Freecad, and most recently to Mario for answering some questions on FCCircularText. I continue to be amazed. As Youtube and trial and error are my teachers for Freecad, thanks also goes to those who have created the instructional videos and posted them on Youtube.
I’m not opposed to sharing my files, but I’m still very much the learner on using Freecad. While functional my 3D drawings tend to be a bit messy.
OS: Windows 10 Version 2004
Version: 0.19.24291 (Git)
The text on the valve handle in my second post was created using the latest version of the FCCircularText macro.
Big and Little Steam Locomotive Parts
- Dick_Morris
- Freecad 3d Model.
- u joint.jpg (7.4 KiB) Viewed 3036 times
- Full sized and 1/4 scale universal joint and filigree valve handle.
- 20210529_230909.jpg (69.14 KiB) Viewed 3036 times
- 1/4 and 1/6 scale universal joints. If you look carefully the lettering is barely visible on the 1/4 scale version.
- 20210610_211336.jpg (70.37 KiB) Viewed 3036 times
- Dick_Morris
Re: Big and Little Steam Locomotive Parts
For my small locomotive I also modeled and cast valve handles for the injector overflow and water cut-off valves and the associated stand at 1/8 scale. When I learned the full-sized locomotive was missing those overflow handles I modified the same 3D model to include the tapered square mounting hole, printed it at 800%, and cast the replacement parts. I was pleasantly surprised that the tapered square mounting hole which was modeled in Freecad per the prototype drawings only required very light clean up with a file to fit the original shaft perfectly. The first of the new overflow handles has now been installed on the locomotive. Personally, I'm partial to the natural bronze color, but I'm not in charge of what gets painted or the color scheme.
- Model from Freecad
- OVERFLOW.jpg (27.76 KiB) Viewed 3029 times
- 1/8 scale valve handles and injector operating stand.
- injector stand reduced.jpg (44.88 KiB) Viewed 3029 times
- New valve handle on the original shaft.
- overflow valve.jpg (22.59 KiB) Viewed 3029 times
- Painted and installed on the Alaska Railroad #557.
- DSCF4108 (1).jpg (70.76 KiB) Viewed 3029 times
Hi
good project, good works thanks for sharing
mario
mario
Very interesting - keep up the good work!
Regards / Viele Grüße
Max
Max
