Raspberry Pi 4B
Raspberry Pi 4B
I needed a Raspberry Pi model for a project the other day. Searching on the Internet, I found plenty of people are searching for exactly that, and plenty of people complaining that the few people that built one are trying to make big money by selling them. I found it surprising that I could not find any reasonable quality free models. Well, maybe I was looking in the wrong places?
Anyway, I made one by myself, and decided to make it available. It should be pretty accurate, as it is based on the 2D drawings available from the Raspberry Pi Foundation. It is not parametrized though, this may be a quality issue for some. But then again, it's for free! This is how it looks:
As you can see, I did not bother with the chicken food (small caps and resistors), only the larger components are there. Should be a fairly exotic project that has a problem with that.
I would have included the FreeCAD model here, but at roughly 1MB it's too big for the forum. However, you can download the model from https://www.rottengatter.de/download/RaspPi-4B.FCStd. If you like it (or dislike it) I'd be happy if you'd leave me your comments in this thread, or what you wanna do with it, or why it's too lousy for your project.
Have fun!
Cheers Peter
Have fun!
Cheers Peter
Re: Raspberry Pi 4B
Thanks for sharing! By cloning the HDMI socket, By resaving with compression level 9 I managed to reduce the size below the 1MB limit here.
- RaspPi-4B.FCStd
- (820.08 KiB) Downloaded 97 times
Re: Raspberry Pi 4B
That is interesting. The second HDMI socket in my model ist just a link to the first one. I always thought a link is the more memory saving way, as a clone seems to have more parameters by itself (for instance it has it's own appearance data - which frequently gets messed up on cloning if the cloned object is too large/complicated). If clones are smaller, then still some more memory can be saved, because there are other items being links that could be converted. For instance the dual USB socket shield is a more complex thing that is just a link in the other dual socket.
I have noticed that a link does not allow certain operations (IIRC for instance the Part:Fusion/Cut/etc.). Otherwise I'm still unsure about in which situations to use clones as opposed to links and vice versa.
BTW. when loading your reposted version I noticed my FreeCAD gives me 15 times this error message (red colour):
08:38:35 Extension is not a python addable version: 'PartGui::ViewProviderAttachExtension'
OS: Windows 7 SP 1 (6.1)
Version: 0.19.23578 (Git)
Hash: 50c3cbf00579dc4941ca743c25720d016b0453ce
Python version: 3.8.6
Cheers Peter
PS.: Hmm, this is even more interesting: When saving again directly after loading your size-reduced version, the file is again 26% larger, i.e. as large as the version I posted on my webspace. So the majority of your size reduction seems to come from more efficient saving code in your newer version!
Re: Raspberry Pi 4B
My bad! I hadn't seen it was a link. The reason why my file is smaller is a completely different one: I use compression level 9. I have updated the post above, and the file is even smaller.
I don't use the very latest FreeCAD either but 0.20 can be the reason for the messages..BTW. when loading your reposted version I noticed my FreeCAD gives me 15 times this error message (red colour):Code: Select all
Re: Raspberry Pi 4B
Does the official 0.19.2 (24291 Git) installation not work on your system? It will read most 0.20pre files without error for the time being and if you find a true bug that can be backported ready for the 0.19.3 then it all helps.perot wrote: ↑Wed Jun 09, 2021 6:56 amCode: Select all
OS: Windows 7 SP 1 (6.1) Version: 0.19.23578 (Git)
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Raspberry Pi 4B
I do not believe in continuous updating. I update occasionally, and if there is concrete cause. My installation is half a year old, which is not unusual (at least for me). I rather spend my precious time using FreeCAD.Syres wrote: ↑Wed Jun 09, 2021 8:09 amDoes the official 0.19.2 (24291 Git) installation not work on your system? It will read most 0.20pre files without error for the time being and if you find a true bug that can be backported ready for the 0.19.3 then it all helps.perot wrote: ↑Wed Jun 09, 2021 6:56 amCode: Select all
Regarding "true bugs": I find weird behaviour all the time. A lot is ephemeral, which I cannot reliably reproduce, or may be due to my outdated video driver (Windows Update refuses to update for unknown reasons, the manufacturer's (Intel) driver refuses because there is a OEM-modified version installed, and the OEM (Dell) does not provide a current one ), for some I have reported here I got told it is due to a OCC problem which therefore cannot be fixed (a rather weird proposition, as OCC is OS too AFAIK). Then again some is due to FreeCAD being used in a slightly off-standard way, which then is rejected by telling that things should be done differently (as if that would ever be a qualified excuse for buggy behaviour).
Here is the problem: The developing people are experts in using FreeCAD, they know exactly how to use each single function. That's why every one of them swears that FreeCAD is very stable. But look a newbie over the shoulder and you'll find buggy behaviour galore.
How about what I reported here (have yet to follow up on replies)? https://forum.freecadweb.org/viewtopic.php?f=3&t=59249
Cheers Peter
Re: Raspberry Pi 4B
I had actually thought the limit is at 512kiB, so that's why I did not even try to look for compression. So what is the 512kiB limit for? Pictures? Or is it the wrong value altogether?
Cheers Peter
Re: Raspberry Pi 4B
According to the forum guidelines it is wrong. Where did you find it?
Re: Raspberry Pi 4B
Where can one find these guidelines, please?
