onepiece();
*end_piece(height2,diam2t,diam2b,rim);
*onepiece();
onepiece();
*onepiece();
WARNING: Ignoring unknown module 'metric_thread', in file onepiecerod7_endPiece.scad, line 70.
I always clamp the filament to the side of the spool with a binder clamp, because I don't want to release the tension on the windings. Even with the stock spool holder and even if it's not turning, the windings loose tension when you pull the filament out. I've also just took the spool off and laid it on the bed before pulling the filament out of the bowden, but even then I still need to hold the filament so it doesn't loose tension.Mikeosaurus wrote: ↑Sun Jul 11, 2021 5:44 pm changing the half used filament roll to a different colour is challenging
