I think since the html code is generated dynamically, it's probably easier to use the qt translation stuff... Inside the py file that generates the page it would be pretty easy to do, same a s i did with the draft module. I can do that!
Have you guys ideas about what else we could add to the start page? (We should really takl about that soemwhere else and stop hacking this thread
Alibre Bracket
Re: Show your FreeCAD projects here!
Cooool!I think since the html code is generated dynamically, it's probably easier to use the qt translation stuff... Inside the py file that generates the page it would be pretty easy to do, same a s i did with the draft module. I can do that!
Yea, somehow for the major parts video tutorials on Youtube (as external links).Have you guys ideas about what else we could add to the start page?
Maybe we can create a FreeCAD channel so we don't have to change always links...
And Yorik,
I need a color adwise for the Sketcher in edit mode, I do at the moment the construction lines
and added the reference coordinate system on the sketch. I need someone with your fealling
for color and space to adjust the look of that stuff....
And I add some Icons which always look bad
Stop whining - start coding!
Ok, I'll have a look and i tell you what i think
I beg you!!!yorikvanhavre wrote:We should really takl about that soemwhere else and stop hacking this thread
Thanks to kwahoo, there's a whole new topic to continue the otherwise very interesting discussion.
