ABeton wrote: ↑Tue Apr 13, 2021 7:12 pm
Also one thing to add I have a problem when I want to import models from the BIM Objects Library. There is the online option but when I activate it, it doesnt work. also There are some links below to webistes like BIM object and when I try to open them, it does not work. So was just wondering what could be the problem?
ABeton wrote: ↑Wed Apr 14, 2021 10:16 am
When I click the "Online" option, the library becomes empty. Also the links to BIM model websites do not work.
For the BIM model websites. You must write a word in search, and then you can click on a web button.
I don't know if you need some configuration for online option. But if the online option does not work you can download the library.
::bitacovir::
================== One must be absolutely modern.
Ahhhhh ok, it works hahahahha It's a great option and the pages load fast. I have been trying to open the BIM model websites for a year I think in this way but never thought of using search hahaha.
So it is only the online option, it is not much of problem, I have the library downloaded, I just found it interesting. Anyway thank you!
So I mostly finished the second floor. I decided to split the floors up using Link Group so now each floor is in a separate file and they are all linked to a master file.
Pasted Layer #3.png (513.53 KiB) Viewed 2290 times
Pasted Layer #4.png (518.13 KiB) Viewed 2290 times
Pasted Layer #5.png (401.96 KiB) Viewed 2290 times
Pasted Layer #6.png (524.95 KiB) Viewed 2290 times
Pasted Layer #7.png (246.63 KiB) Viewed 2290 times
Below are the 2D drawings generated from the 3D model both in FreeCAD and exported to QCAD. I used the legacy DXF exporter and it worked perfectly. Layer colours were exported and the exported surfaces could be easily hatched without doing any changes.
I tried to use Techdraw first, but I think that the furniture drawings are too heavy for it.
Pasted Layer #2.png (117.24 KiB) Viewed 2286 times
Pasted Layer #9.png (181.89 KiB) Viewed 2286 times
Pasted Layer #10.png (185.79 KiB) Viewed 2286 times
Pasted Layer #11.png (172.05 KiB) Viewed 2286 times
