Page 18 of 39
Re: call for screenshots - By Yorik
Posted: Sat Nov 20, 2021 3:11 pm
by jimmihenry
chrisb wrote: ↑Sat Nov 20, 2021 11:54 am
jimmihenry wrote: ↑Sat Nov 20, 2021 12:52 am
Here is a project a had a lot fun with, It is a remote controlled plane.
Nice project. It is made of foam, right? Does the propeller always stop in horizontal position? so it won't break on landing?
Hey Chrisb, yes the plane is made out of foam, 6mm insulating foam sheet for home constriction. Also known as Depron.
Had the same concern, breaking the prop when landing. The prop doesn't always stop in horizontal position but it never
broke or got damaged in the landing process. To be honest i never landed on concrete or tarmac or any other hard surface.
Guess if the prop is in any other position then horizontal it will turn as soon as it hits a object, further more the prop is
fasten with a rubber, this will also prevent damage...
Posted: Sat Nov 20, 2021 5:54 pm
by chrisb
Thanks for the info. I guess that every additional stuff - mechanical or electronic - which makes the propeller stop horizontally, will add undesired to the weight.
Posted: Sat Nov 20, 2021 11:58 pm
by Misacsnk
Ok amigo! obrigado pela dica.
Posted: Sun Nov 21, 2021 4:43 pm
by jimmihenry
Must admit the logo section is well disciplined, strictly follwing the guide lines! Just went there to have a look.
So far this one by
Gavinlynas would be my favourite. The green version of this logo is also pretty nice but it
should have the FreeCAD colours.
Posted: Mon Nov 22, 2021 8:46 pm
by OficineRobotica
I wanted a reason to use the water mark
Posted: Mon Nov 22, 2021 9:53 pm
by ragohix769
OficineRobotica wrote: ↑Mon Nov 22, 2021 8:46 pm
I'm speechless!
Posted: Wed Nov 24, 2021 1:28 am
by jimmihenry
200 steps per revolution outstanding repeatability. Used in applications like scanners, floppy drives, disk drives, CNC machinery and
most downloaded model on my GrabCAD. Yes it is a Stepper motor, precisely NEMA17 x 40mm about 45cm holding torque @ approximately
2 Amps. Here is the link to this model and some other NEMA17's.
Nema17 x 33mm:
https://grabcad.com/library/nema17-x-33-1
Nema17 x 40mm:
https://grabcad.com/library/nema17-x-40-1
Nema17 x 48mm:
https://grabcad.com/library/nema17-x-48-1
Nema17 x 60mm:
https://grabcad.com/library/nema17-x-60-1
Cheers.
Posted: Wed Nov 24, 2021 9:07 am
by OficineRobotica
FreeCAD's start page with notes option active. Handy feature indeed.
- StartPage.jpeg (357.92 KiB) Viewed 7370 times
Posted: Wed Nov 24, 2021 1:48 pm
by yorik
@OficineRobotica does the Notes tab fully work for you? Are the notes kept between FreeCAD sessions? For me (Linux) it still doesn't work, and I can't find what's wrong (something to do with Qt web engine's local storage settings...)
Posted: Wed Nov 24, 2021 4:44 pm
by OficineRobotica
yorik wrote: ↑Wed Nov 24, 2021 1:48 pm
Bare in mind I'm on linkstage3. The notes are kept but the notes panel is always shrinked on restart. It would be nice to habe it remember the dimension. Could you please do something about that? Notes are really useful.
Also linux and AppImage
