call for screenshots - By Yorik
jimmihenry
Re: call for screenshots - By Yorik
Post by jimmihenry »
chrisb wrote: Sat Nov 20, 2021 11:54 am
jimmihenry wrote: Sat Nov 20, 2021 12:52 am Here is a project a had a lot fun with, It is a remote controlled plane.
Nice project. It is made of foam, right? Does the propeller always stop in horizontal position? so it won't break on landing?
Hey Chrisb, yes the plane is made out of foam, 6mm insulating foam sheet for home constriction. Also known as Depron.
Had the same concern, breaking the prop when landing. The prop doesn't always stop in horizontal position but it never
broke or got damaged in the landing process. To be honest i never landed on concrete or tarmac or any other hard surface.
Guess if the prop is in any other position then horizontal it will turn as soon as it hits a object, further more the prop is
fasten with a rubber, this will also prevent damage...
Thanks for the info. I guess that every additional stuff - mechanical or electronic - which makes the propeller stop horizontally, will add undesired to the weight.
Misacsnk
Post by Misacsnk »
carlopav wrote: Sat Nov 20, 2021 10:16 am
Misacsnk wrote: Fri Nov 19, 2021 10:03 pm What about?
I have to say that it's a good effort to gently improve the current logo. Mind to post it here: https://forum.freecadweb.org/viewtopic.php?f=34&t=50640. In this way it could be taken into account in the future.
Ok amigo! obrigado pela dica.
jimmihenry
Must admit the logo section is well disciplined, strictly follwing the guide lines! Just went there to have a look.
So far this one by Gavinlynas would be my favourite. The green version of this logo is also pretty nice but it
should have the FreeCAD colours.
FreecCAD Logo by Gavinlynas.gif (744.1 KiB) Viewed 7727 times
OficineRobotica
Post by OficineRobotica »
I wanted a reason to use the water mark :)
Check out my Youtube channel at: https://www.youtube.com/@OficineRobotica
ragohix769
Post by ragohix769 »
OficineRobotica wrote: Mon Nov 22, 2021 8:46 pm I wanted a reason to use the water mark :)
I'm speechless!
jimmihenry
200 steps per revolution outstanding repeatability. Used in applications like scanners, floppy drives, disk drives, CNC machinery and
most downloaded model on my GrabCAD. Yes it is a Stepper motor, precisely NEMA17 x 40mm about 45cm holding torque @ approximately
2 Amps. Here is the link to this model and some other NEMA17's.
Nema17 x 33mm: https://grabcad.com/library/nema17-x-33-1
Nema17 x 40mm: https://grabcad.com/library/nema17-x-40-1
Nema17 x 48mm: https://grabcad.com/library/nema17-x-48-1
Nema17 x 60mm: https://grabcad.com/library/nema17-x-60-1
Cheers.
OficineRobotica
FreeCAD's start page with notes option active. Handy feature indeed.
yorik
Post by yorik »
@OficineRobotica does the Notes tab fully work for you? Are the notes kept between FreeCAD sessions? For me (Linux) it still doesn't work, and I can't find what's wrong (something to do with Qt web engine's local storage settings...)
OficineRobotica
yorik wrote: Wed Nov 24, 2021 1:48 pm @OficineRobotica does the Notes tab fully work for you? Are the notes kept between FreeCAD sessions? For me (Linux) it still doesn't work, and I can't find what's wrong (something to do with Qt web engine's local storage settings...)
Bare in mind I'm on linkstage3. The notes are kept but the notes panel is always shrinked on restart. It would be nice to habe it remember the dimension. Could you please do something about that? Notes are really useful.
Also linux and AppImage
