call for screenshots - By Yorik
Re: call for screenshots - By Yorik
I'm working in a low-budget CNC with 2020 Al profile extrusions and 3D-printed parts.
This is the mount for the moto-tool that I have.
- Screenshot from 2022-03-20 21-41-58.png (677.27 KiB) Viewed 6935 times
- jimmihenry
A straight forward design in regards to capture certain degree of freedom & surface pressure, the T-Plug.
View the T-Plug in a 3D browser here: https://grabcad.com/library/deans-t-plu ... d-female-1
- T-Plug.gif (472.33 KiB) Viewed 6486 times
- T-Plug.png (193.63 KiB) Viewed 6486 times
Repeatable Ornament
I'm surprised how well FreeCAD 0.20.28611 is suited for modeling complex curved bodies. All I needed was the Part and Draft workbench and a self-made macro to sweep along two rails. FreeCAD was able to generate an error-free solid from all objects, which could be rendered perfectly with e.g. Blender (see pictures).
Codelink on GitHub: https://github.com/j8sr0230/codelink
Codelink on PiPy: https://pypi.org/project/codelink/
FreeCAD Nodes Workbench on GitHub: https://github.com/j8sr0230/Nodes
- ragohix769
Amazing!j8sr0230 wrote: ↑Thu Apr 07, 2022 9:43 am Repeatable Ornament
Wow, that is really impressive! I must say, that i am not the artistic type, but this is really really impressive. This is even in a high end commercial CAD with special license modules pretty hard. But with FreeCAD, which is not that good freeform surface modeller,
respect!
Greetings
user1234
edit: correct wording
Thanks for sharing. Would you mind publishing the macro?
Hi Chris,
I have put together a small tutorial consisting of a PDF, the FreeCAD file and my macro DistributeProfilesOnRails. You can find it under https://forum.freecadweb.org/viewtopic. ... 47#p587147. Have fun with it!
That looks very cool and a great example on how to use FreeCAD.jimmihenry wrote: ↑Sun Jan 02, 2022 10:38 pm Hello, and a happy new year to all! Some time ago i stumbled over a DIY vice video on you tube, this one cached my interest
because it was so shiny red. It also was a slick simple design. The original called Fireball Tools DIY vice has some thrust bearings,
i did not include these... My model is not the one from Fireball Tool, i did not buy the plans, i don't provide the welds for joining
the sheet metal, my dimensions are not related to hardware you could purchase. The purpose of my model is to have a idea of
the design. You may wont to alter the model for your needs if you choose to make one of these for yourself.
CAD and STEP model are available here: https://grabcad.com/library/diy-vice-1
- jimmihenry
Thank you jhaand .
Here is a sneak a peek of a abandoned project. I had a toy MUTT for 3D print in mind. Maybe as FreeCAD
progresses i will come back for this project... (probably not).
Ford M151 Multi Utility Tactical Truck
- My Willy.png (81.41 KiB) Viewed 4627 times
Hello Community,
I am currently working intensively with generative designs. My goal is to use FreeCAD for projects that I would normally use Rhino's Grasshopper or Blender's Geometry Nodes for. To start with, I have been working on a DualMesh implementation. With the attached scripted FreeCAD object "DualMesh", triangle meshes can be decomposed into their dual representation. If you are interested, simply download the module "DualMesh.py", move it to your macro directory and execute the following code from your FreeCAD terminal (don't forget to start by creating a new FreeCAD document):
The code creates a mesh ellipsoid and generates the corresponding dual mesh as a clean solid. Scaling of the generated elements and extrusion thickness can be varied parametrically via corresponding properties (see figures). This can be done with all triangular meshes from Mesh WB.
import DualMesh
DualMesh.makeExample()
- DualMesh.py
- Scripted FreeCAD Object
- (2.97 KiB) Downloaded 55 times
