call for screenshots - By Yorik
- jimmihenry
Re: call for screenshots - By Yorik
Here is a quite popular part for the 3018CNC. The ER11 tool holder system, it is a set of the holder, a collet,
and nut. It fits a 5mm shaft of the milling motor and allows due the different bore sizes in the changeable
collets to have a rage of bits mounted. This is a very nice piece of hardware .
P.S.: Threads are not displayed!
The animation does not show the proper mounting order!
To mount a bit push first the proper sized collet into the nut!
- 2.png (60.36 KiB) Viewed 17869 times
- ER11 Chuck Set 640x480 idx256.gif (925.67 KiB) Viewed 17869 times
Measurement arm thing. Joints are planetary gearboxes.
Mini XLR barrel thing.
Mannequin shoulders, attempt at compound curves in FC.
Motor drive for microscope focus.
2-axis rotating sample platform for doing photogrammetry of small objects.
- jimmihenry
Ho ho ho Santa got a brand new 775 DC motor in his bag...
forgot to mention.... Here is the model if you like to view it in 3D!
https://grabcad.com/library/775-dc-moto ... -bearing-1
- 775 DC Motor 000.gif (964.32 KiB) Viewed 17771 times
drawing of two pieces...
A truncated Icosahedron,... just patience for the assembly with the A2PLUS workshop
you may use my screenshot
bonjour,
dessin de deux pièces...
Un Icosaèdre tronqué,... juste de la patience pour l'assemblage avec l'atelier A2PLUS
bonjour,
- capture
- capture.png (322.05 KiB) Viewed 17039 times
- jimmihenry
Achtung Pterodactylus!! Be aware of the big bird .
It is a 3D puzzle made from a DXF i found years ago on the internet, the file was pure horror made primary out of errors as i remember.
Back than I was using a different CAD program. I remade this little fellow using FreeCAD, the scaling was going well, converting into a
sketch was easy. The validate feature was very helpful! . Extrusion is supported by a Spreadsheet to control the material thickness
and slot width that makes the parts slide into eachother. However i tried to position the parts... Nope i gave up! Inconvenient and time
consuming to say at least. The animated gif was made using the old model converted into a STEP file. Cheers.
P.S. I attached a simple copy for those who are familiar with positioning parts in FreeCAD.
- Flugsaurier Simple Copy FreeCAD 0.2.FCStd
- (194.63 KiB) Downloaded 220 times
- Pterodactylus.gif (839.35 KiB) Viewed 16842 times
The assembled version with A2plus
Nice exercise.
Nice exercise.
- Pterodactylus.png (269.46 KiB) Viewed 16223 times
- jimmihenry
Here is one of my earlier projects. It is a Arcade Joystick. Speciality of this bugger is the capability to serve as a pinball controller,
(because of the buttons on each side). So it is a true Arcade- Pinball- Joystick with 20 buttons and a Sanwa joystick. On the front is a
XLR USB connector mounted, takes a cable like the one on your printer and that's noice . It is a frame made like a arcade cabinet,
the top plate and bottom are screwed on. The buttons are like the ones on real pinball and arcade machines the micro switches are as
cheap as ....
Working with hand tools and material from home depot was challenging because of the tight fit of the components. After all everything
went smooth, the Arcade- Pinball- Joystick a full success. If you missed out on Speed Link Competition Pro you are well suited with
this one i am sure!
Parts used:
1. Happy Style Arcade Buttons.
2. Zero Delay USB Encoder (PS3 Compatible).
3. XLR CP30111 B A Gender Change Feed Through Socket.
4. M5 Thread inserts.
5. Some screws and wood.
Link to the model: https://grabcad.com/library/arcade-pinball-joystick-1
cheap as ....
this one i am sure!
Parts used:
- Arcade-Pinball-Joystick.gif (952.35 KiB) Viewed 15928 times
Pretty nice thread with awesome projects.
Here is my contribution.
My fully working peephole camera that goes mounted hidden inside the house, and not outside like other cameras.
It is easily detachable to access the peephole fast if needed.
The mainboard is a Raspberry Pi Zero W.
My files are here if someone is interested
https://www.dropbox.com/sh/cuxo9anzhqjf ... YvjWa?dl=0
- ifohancroft
Noice!
jimmihenry wrote: ↑Fri Dec 17, 2021 3:13 am Here is one of my earlier projects. It is a Arcade Joystick. Speciality of this bugger is the capability to serve as a pinball controller,
cheap as ....
this one i am sure!
Parts used:
I like making, breaking and modding stuff, using a soldering iron, code or both. https://ifohancroft.com
- jimmihenry
I've made a old school drone .
Just the wing tips are not as they should be, i wish i would have the feature to pull multiple
profiles along multiple sweeps. Maybe next Christmas Santa will have a present code.
This model "Fiesler Fi 103 (FZ 76) V1" is on Wikipedia and it is very poor detailed in form of a
blueprint. I found a plastic model kit manual which i could put to good use.
If you like the applied textures go to the FreeCAD main Menu -> View -> Texture mapping...
- Fiesler 103 (FZG 76) V1 texture slow ani.gif (767.15 KiB) Viewed 15156 times
- OP.png (196.83 KiB) Viewed 15156 times
