call for screenshots - By Yorik
Re: call for screenshots - By Yorik
- Capture.JPG (145.1 KiB) Viewed 11744 times
Great job! Note: please consider posting FreeCAD v0.19 videos to youtube instead of v0.18. Thanks!
Hello Kunda 1
Did you Watch the video , I try to introduce a new features that make the modelling better and faster, i'm Sure the main developer could implement better than what i did
FreeCad v0.19 better than v0.18 but the problem on me, because i'm not familiar with PyQt5
- jimmihenry
here is my Crimp Connector... It is one body.
Image 01.
And a v-bit for engraving, 100% pointy/ sharp. No flat or rounded tip!
It took a workaround to achieve this geometry due the method i attempted
first did not allow a sharp/ pointy tip.
Image 2.
Cheers.
Image 01.
Image 2.
Cheers.
- Crimp Terminal.gif (788.42 KiB) Viewed 4074 times
- V-Bit.gif (589.86 KiB) Viewed 4074 times
- OficineRobotica
Bk12 screw holder and 10x10 shaft motor coupler modeled in FreeCAD Linkstage3. Other than really enjoying modeling the components, I'm posting this to showcase the current render quality of the new ExperimentalRenderer (key word: experimental) .
You can learn more about Realthunder's roadmap here: https://youtu.be/-K1EVcYAmRM?t=1448
Support Realthunder's endeavour here: https://www.patreon.com/thundereal
Check out my Youtube channel at: https://www.youtube.com/@OficineRobotica
- jimmihenry
This is a Hextronik 24g BL- Motor, there are more knock off's as i know. The original motor is called Blue Wonder.
A highly efficient motor for a slow flyer. It runs on a three cell LIPo (11,1Volts) and drives a huge prop for it size 8"
(203,2mm).
Cheers
(203,2mm).
Cheers
- Hextronik 24g BL.gif (910.66 KiB) Viewed 3989 times
This is a male version of the humanoid robot made with same workflow as this thread:
https://forum.freecadweb.org/viewtopic.php?f=24&t=60239
The inner endoskeleton made by subtracting 5mm shell from a 2mm shell leaving al 3mm internal shell (yellow) to which 2mm body shell parts (purple / blue) are attached with perfect mating of surfaces.
- jimmihenry
Hi, this is called a Happy Style Arcade Button it is made 100% in FreeCAD. Even the Animation is
made with a FreeCAD Macro called Screen Wiki .
Cheers.
Cheers.
- Happy Button.gif (700.63 KiB) Viewed 3989 times
And a raytraced render done in Blender
