Earbuds model with approximation
MrCAD
Post by MrCAD »
Modeling of my own Realme Earbuds in FreeCAD 0.19.
Three workbench used back-to-back; Curves WB, Part WB, and Surface WB.
Faced difficulties / problems:
1) The blue colored body cannot UNION with rest of the model, neither in Part WB nor in PartDesign WB.
2) Won't able to make earpiece after making a solid body of all surface used in Curves WB.
Suggestions:
Let me know if anybody would figure out how to boolean two different body which is made with other than PartDesign WB.
I made two model for modeling of Earpiece (semi transparent soft fabric in Black color), because of the problem faced mentioned above (second).
Final Ear Buds.FCStd
(63.21 KiB) Downloaded 35 times
EarBuds.FCStd
(183.18 KiB) Downloaded 42 times
OS: Windows 10 Version 1909
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Hash: a88db11e0a908f6e38f92bfc5187b13ebe470438
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: English/India (en_IN)
thschrader
Re: Earbuds model with approximation
Post by thschrader »
MrCAD wrote: Sun Mar 28, 2021 12:20 pm ...
you have inner faces in the earbud solid. I did this:
1. downgrade earbud-solid to individual faces with arch-wb.
2. eliminate faces 5+17, the inner ones.
3. curves-wb: make solid from remaining faces.
4. part-wb: fuse all bodies.
BTW: interesting project :)
Final Ear Buds_ts.FCStd
(254.19 KiB) Downloaded 37 times
MrCAD
Post by MrCAD »
Good to know that you used Arch-Wb for this purpose, which I wasn't aware about . I'll definitely give it a try in next project, thanks for the tips.
Thank you, will try more projects on surface designs like this one, which is my weakness in modeling.
freedman
Post by freedman »
How do you know if you have it right, you can hardly hold the darn things? Ya! good project.
