House Walls using Sketches
AndrewA
Post by AndrewA »
OS: Debian GNU/Linux bullseye/sid (XFCE/xfce)
Version: 0.19.23964 (Git) AppImage
Hash: db9525e7d78c956df96dd6db2c52f20a50a2aa5f
Python version: 3.8.6
After @Paullee helped fix an error I had made it was suggested that I upload this model to the Showcase, so here goes. The above version information is the latest AppImage version, I have followed the AppIage release since I started on this model in mid January.
In designing a house to accommodate a multi-generational family, I had mocked up some base designs in SweetHome3D
MockUp.sh3d
However the final design would need so room size tweaking. To do this I decided to use sketches with length constraints. As recommended on the wiki, I split the sketches up into smaller parts, linked together with external geometry. This also means that walls can be grouped by thickness and changes to the internal rooms change the external walls, keeping the ground floor and first floor the same size. However, some changes to sketches, like removing a line, change some of the names of other lines, which can break external links. There are also links to some external geometry of roofs and walls, eg for the ridge tiles. These seem to get the edges renamed very easily, especially when using another solid to cut out part of the wall or roof. If I was to do this again, I would look to find a better method do these links.
20210219Fixed.FCStd
Creative Commons Attribution-ShareAlike
My output is for a planning application so needs to be plans and elevation in 2D so I am using the svg output.
I use the svg output instead of the pdf, as the pdf output seems not to respect the line width or page orientation, although that could be my lack of knowledge. Also it can be seen below that there are errors, like bits of roof in the wrong place, plus I like to remove the joins in the walls, change colours etc. I'm using Inkscape to finish off, which is a little tedious. Hopefully by FreeCAD V1.0 it will not be needed. Below is the pdf export from Inkscape with no adjustment, as the svg files are too large to post. Still working on the finalising, I will post when I have a final output
Forum-Elevations.pdf
(66.45 KiB) Downloaded 102 times
Forum-Plans.pdf
(44.04 KiB) Downloaded 132 times
I hope people find this useful for their own projects
Andrew
bernd
Re: House Walls using Sketches
Post by bernd »
Would you post your version number which where used to crete the sketches?
On the FreeCAD I sit at, I get an error message, "The sketch is invalid and cannot be edited."
Version: 0.19.22960 (Git)
Hash: c5a4b01d2e4218bcc0eb6650337650a6c65ef0e4
Python version: 3.6.8
Qt version: 5.12.1
paullee
Post by paullee »
bernd wrote: Mon Feb 22, 2021 10:32 am On the FreeCAD I sit at, I get an error message, "The sketch is invalid and cannot be edited."
Which Sketch ? It seem it is fine here - Appimage git 23578 to 23964, on Fedora 30.
paullee
Post by paullee »
AndrewA wrote: Mon Feb 22, 2021 8:59 am However, some changes to sketches, like removing a line, change some of the names of other lines, which can break external links. There are also links to some external geometry of roofs and walls, eg for the ridge tiles. These seem to get the edges renamed very easily, especially when using another solid to cut out part of the wall or roof. If I was to do this again, I would look to find a better method do these links.
See some 'workaround' on the original thread in Draft, Arch & BIM Forum
BTW, you may like to add the Plan & Elevation which looks very nice on the OP?
bitacovir wrote: Ping
Good to post on OSArch ?
bitacovir
Post by bitacovir »
paullee wrote: Mon Feb 22, 2021 2:46 pm
Sure.
AndrewA wrote: Mon Feb 22, 2021 8:59 am In designing a house to accommodate a multi-generational family, I had mocked up some base designs in SweetHome3D however the final design would need so room size tweaking.
Can you edit your first post, including images of the mockup made with sweethome3D? This way we can show a full workflow from SH3D to FreeCAD.
https://wiki.osarch.org/index.php?title ... .282021.29
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
AndrewA
Post by AndrewA »
I think that I have covered everything above by editing the first post, if not please feel free to give me a poke.
ragohix769
Post by ragohix769 »
Thanks for sharing! :D
This is the kind of real world project (architeture) that I like, and this example is really useful to study for anyone (at least I still cannot produce such a polished project and draw, congrats!).
I'll try to study your work and do some other realworld houses with sketches; I want to use 100% OSS like Freecad in my work (now I use Autocad, Revit and SKUP), it's very hard to switch from.
bernd
Post by bernd »
bernd wrote: Mon Feb 22, 2021 10:32 am Would you post your version number which where used to crete the sketches?
Qt version: 5.12.1
If the file is opened with a newer Version of FreeCAD the sketches opens just fine ...
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.19.24246 (Git)
Build type: Unknown
Hash: 7149c80f81bfd1c2e384e4bb93e0723711c7fb62
Python version: 3.7.3
Qt version: 5.11.3
AndrewA
Post by AndrewA »
With a bit of work in inkscape I hope I have have fixed the problems and made it a little prettier.
In Inkscape everything seems to be included twice, once as a file and once as an outline, which all have the same thickness. Selecting an outline and selecting the same style all of these can be removed. The files are generally of different colours, so selecting the same fills, then outlines can be added in Inkscape of different thicknesses and the colours changed. The only tedious bits are the windows, where the frames are the same colour as the glass, so these had to be done manually.
I also exported the file as glb to get it into Blender, It was a bit broken. (other formats where broken far worse with no materials, which would make the windows very tedious.)
The main problems being selecting the walls does not export the windows, so each has to be selected separately. Also on import, various things are not in the right place. Generally the xyz and rotation can just be copied from the FreeCAD file. It looks like FreeCAD or Bender cannot export or import some objects, but stil transfers some of the information like the name and position. So in the Blender file I get what was called window001 named roof002. This only seems to happen with big files so it is difficult to track down and report as a bug. The Greenhouse was a different FreeCAD file.
Most of it was easy to fix to get
paullee
Post by paullee »
Looks great !
