that is a good idea. there could be 2 versions. minimal version with compensating gear made of angle grinders. version 2 with car batteries and hub motorjonasb wrote: ↑Mon Dec 27, 2021 1:47 pm You could install a simple differential. The required bevel gears may be recovered from old angle grinders.
Avoid waste with freecad through upcycling. velomobile, bicycle trailer. save water, energy ......
- thomas-neemann
Re: Avoid waste with freecad through upcycling. bicycle trailer. save water, energy ......
Very quick and dirty, using PartDesign, FCGear and Assembly4, loosely based on this image from amazon.
(the file itself has 6.4 MB, so a bit large to attach here)
- thomas-neemann
- thomas-neemann
front axle simplest construction made of round steel
part 4
https://www.youtube.com/watch?v=z2iBkqeRBFc
part 4
- thomas-neemann
- 1.png (108.61 KiB) Viewed 3089 times
- thomas-neemann
part 6 rear wheel steering
the open source velomobil can be downloaded here. (own responsibility)
https://drive.google.com/file/d/1j-tCWu ... sp=sharing
https://www.youtube.com/watch?v=aZ4hTf4EQ-E
demonstration rear wheel steering
https://www.youtube.com/watch?v=scEPvTjLvkc
Have you driven forklift truck?
Rear wheel steering at speed will be "interesting"
Good luck
Good luck
- thomas-neemann
that's how I see it, but if you drive a maximum of 30 kmh in the city, it should be safe
Interesting for sure, but real problems occur only if you have a negative caster angle.
- thomas-neemann
update
Solar panels provide shade and charge during the journey and when parking (during the day)
