My Drawings
kisolre
Re: My Drawings
Post by kisolre »
I just noted the Solvespace screenshots. Did you also use the dev version there?
mhalil
Re: My Drawings
Post by mhalil »
kisolre wrote: Thu Dec 10, 2020 7:02 pm I just noted the Solvespace screenshots. Did you also use the dev version there?
Yes I am using dev version of SolveSpace (v 3.0-bdd2be60).
mhalil
Re: My Drawings
Post by mhalil »
Part No 49
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-49-1
Part No 55
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-55-1
Part No 57
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-57-1
Part No 58
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-58-1
Part No 59
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-59-1
Part No 61
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-61-1
Part No 62
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-62-1
Part No 63
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-63-1
mhalil
Re: My Drawings
Post by mhalil »
Part No 65
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/parca-no-65-1
Egzersiz No 742
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-742-1
Egzersiz No 755
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-755-1
Egzersiz No 756
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-756-1
Egzersiz No 762
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-762-1
Egzersiz No 960
Download (.FCStd, .STL, .OBJ) File: https://grabcad.com/library/egzersiz-no-960-1
Egzersiz No 873
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-873-1
Egzersiz No 931
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-931-1
Egzersiz No 972
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-972-1
Egzersiz No 977
Download (.FCStd, .STL) File: https://grabcad.com/library/egzersiz-no-977-1
Kül Tablası
Download (.FCStd, .STL) File: https://grabcad.com/library/kul-tablasi-2
Açık Ağız Anahtar
Download (.FCStd, .STL) File: https://grabcad.com/library/acik-agiz-anahtar-2
thschrader
Re: My Drawings
Post by thschrader »
Man, awesome work.
I like your renderings.
Why do you use FC/solvespace parallel (I have no idea what solvespace is, sorry...)
kisolre
Re: My Drawings
Post by kisolre »
fmluizao
Re: My Drawings
Post by fmluizao »
Amazing showcase :)
A little question... How do you export to XHTML?
mhalil
Re: My Drawings
Post by mhalil »
thschrader wrote: Sun Dec 13, 2020 8:31 pm Man, awesome work.
Hi thanks.
I want to try and learn many open source CAD software.
SolveSpace is a very capable and extremely easy to use software.
Moreover, the file size is quite small.
fmluizao wrote: Mon Dec 14, 2020 11:52 am Amazing showcase :)
Thanks.
I export the models in XHTML format so that users who do not have CAD software on their computers can view the models.
You can Export your model to XHTML like this;
1 - Select your model
2- Run Export command ( File > Export...) shortcut CTRL + E
3- Select XHTML type from "Files of Type" List
and Save it.
fmluizao
Re: My Drawings
Post by fmluizao »
Never noticed that option in export dialog :oops:
Thanks!
mhalil
Re: My Drawings
Post by mhalil »
fmluizao wrote: Mon Dec 14, 2020 2:25 pm Never noticed that option in export dialog :oops:
Thanks!
You're welcome
