Szzer wrote: ↑Thu Oct 15, 2020 7:58 aml
I've ran into a workflow issue... I prefer to put the first setup of how the walls look like in a sketch, this makes editing afterwards much easier for me.
Thanks for testing! No, that's not possibile Indeed. At least not yet. There Is an axis align property that could allow you to align the Wall segmento to a master sketch segment, but i'm not sure It Will work properly.
Also can the door be modeled in an open position? It helps me visualize the space needed for a opening door a lot better.
Also here, not in the default opening, but you can use your custom Door and Windows modeled in part design opened or closed as you Wish.
@paullee, @bitacovir, consider that maybe Szzer could not want to publish his own house into osarch. So i suggest to wait for his ok for that.
