Parametric (Mostly) Carport
I designed a free standing carport that has many parametric (variable) features. You can quickly modify the length, width and height of the carport. You can also modify the roof pitch and dimensions of many of the objects in the model. I developed a new (at least to me) way of using a SS to make it easier for me to work in US units as well as implementing the parametric values.
I am relatively new to FC (~2 months, off and on). More experienced users will likely find a lot of things in my model that could be done better. I don’t present my model as an example of “the best” way to do things in FC. I share it in hopes that it will inspire someone else with some new ideas and also to solicit constructive feedback as to ways I can improve my knowledge and productivity in using FC.
I attached the FC file as well as a PDF with more detailed information.
OS: Ubuntu 18.04.4 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.22039 (Git) AppImage
Hash: 2bfc6301bc80c0344cbf13dbfe041fbd78cac93d
Python version: 3.8.2
- Parametric (Mostly) Carport.pdf
- (385.36 KiB) Downloaded 272 times
- Carport.FCStd
- (48.6 KiB) Downloaded 191 times
Re: Parametric (Mostly) Carport
Thank you very much for sharing your knowledge.
But, maybe it's me, being a FC novice, I see nothing
- carport.png (168.03 KiB) Viewed 3861 times
Try the FitAll icon to recenter 3D view. The Cylinder you are trying to move seems to be invisible, but I may be mistaken from the screenshot.
- Gregory son of Carl
I'm also having problems loading the model in version 0.19. FreeCAD isn't recognizing the draft objects and is giving me 'ModuleNotFound' errors.
Aside from that, I appreciate the report you included with your project. It paints some nice insight into the new user experience. The advice I have from just reading your report is that using tools across different workbenches is generally fine and often encouraged with a notable exception of mixing the Part and PartDesign workbenches. I'd also like to praise your section titles for being written in glorious comic sans.
<string>(1)<class 'ModuleNotFoundError'>: No module named 'draftobjects.clone'
<string>(1)<class 'ModuleNotFoundError'>: No module named 'draftobjects.array'
<string>(1)<class 'ModuleNotFoundError'>: No module named 'draftviewproviders.view_clone'
<string>(1)<class 'ModuleNotFoundError'>: No module named 'draftviewproviders.view_draftlink'
I just downloaded the FC file that I posted (to a different location) and it opens fine.
@hast66
I don't understand why your combo view tree shows all those "Unnamed" objects. I see nothing like that in my model. Are you using V.19?
@Gregory son of Carl
Again, no idea why you're getting errors. I'm using a Linux App Image, V.19. Perhaps there is some bundling included that isn't included in other downloads? Just guessing. Others more knowledgeable about the packages might have some insight.
@hast66
I downloaded the FCStd file, opened it, and took a screen shot. I did nothing else. Looks fine to me.
OS: Windows 7 SP 1 (6.1)
Version: 0.19.22111 (Git)
Hash: cb2099aa6bb287a8d7843eb70684cce79bdef26b
Python version: 3.6.8
Qt version: 5.12.1
Gene
Qt version: 5.12.1
Gene
I re downloaded and tied again but got the same result.
Does in it only goes well in 0.19. I have 0.18
OS: Windows 10
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
Locale: Dutch/Belgium (nl_BE)
OS: Windows 10
Qt version: 5.6.2
Alright, it's working now. Just needed to download the latest development AppImage.
I'd say this is a pretty stellar model. The tree is well organized and the part names make it easy to interpret and relate to the spreadsheet parameters. The spreadsheet offers a robust amount of adjustments and updates seem pretty stable when I'm not deliberately trying to break it. One thing I felt was missing from the spreadsheet is the ability to adjust the spacing/number of middle rafters. That said, I have no idea what makes a good carport, but this seems like a decent tool for starting such a project. Thank you for sharing your work. Here's where I'm gonna park my Dodger Dog.
- ChapelOfTheDogs.png (13.69 KiB) Viewed 3617 times
Ok, that does look complicated. I would like to build a new carport near my house, but I am not sure I will be able to plan it out and build it all by myself entirely.
The carport I have near my house was made by carportaustralia.com.au, and I will ask them for help this time, too. At least for the project because I don’t know what materials to use and how to do the math, so it’s cheaper to build it.
I want to build another one because my elder son has a car too and I want him to have a place to store it too. And when he moves out, it will be a place for my tractor and other stuff.
