ELT-MAORY with FreeCAD-Assembly4
easyw-fc
Re: ELT-MAORY with FreeCAD-Assembly4
Post by easyw-fc »
Zolko wrote: Sun Jan 26, 2020 7:00 pm
ⵎⴰⵙⵏⵙⴰⵏ wrote: Sun Jan 26, 2020 11:52 am What CAD system was used for the actual design of the ELT?
I don't know. And there might be more than one, because some parts are done by subcontractors.
if you open the STEP files with a text editor, you should be able to know the last STEP producer/exporter.
the header is something like this:
ISO-10303-21;
HEADER;
FILE_DESCRIPTION (( 'STEP AP214' ), '1' );
FILE_NAME ('sphere.STEP','2016-09-25T16:33:48',( '' ),( '' ),'SwSTEP 2.0','SolidWorks 2014','' );
FILE_SCHEMA (( 'AUTOMOTIVE_DESIGN' ));
ENDSEC;
DATA;
In FC you get something like the following:
ISO-10303-21;
HEADER;
FILE_DESCRIPTION(('FreeCAD Model'),'2;1');
FILE_NAME('example.step','2020-01-13T07:43:58',(
    ''),(''),'Open CASCADE STEP processor 7.3',
  'FreeCAD','Unknown');
FILE_SCHEMA(('AUTOMOTIVE_DESIGN { 1 0 10303 214 1 1 1 1 }'));
ENDSEC;
DATA;
Zolko
Post by Zolko »
easyw-fc wrote: Sun Jan 26, 2020 8:45 pm
SolidWorks 2009
ISO-10303-21;
HEADER;
    '1' );
FILE_NAME ('E-ELT Instrumentation#10000001.STEP',
    '2009-07-19T07:54:10',
    ( 'kao' ),
    'SwSTEP 2.0',
    'SolidWorks 2009',
ENDSEC;
try the Assembly4 workbench for FreCAD v0.19
install with Tools > Addon Manager > Assembly4 — tutorials here and here
ⵎⴰⵙⵏⵙⴰⵏ
Post by ⵎⴰⵙⵏⵙⴰⵏ »
I had no idea about that, thanks for the tip easyw-fc.
Zolko
Post by Zolko »
This model from MAORY has been chosen by Phoronix to illustrate the release of version 0.19 of FreeCAD:
https://www.phoronix.com/scan.php?page= ... eeCAD-0.19
That was an old model, we have updated it, and the new one is quite different, you can find more info on ESO's site and the consortium's site. We have recently released the PDR documents (Preliminary Design Review) and I have used FreeCAD to make the illustrations, and I'm happy to say that FreeCAD's assembly is both powerful and easy to use.
jcoppola
Post by jcoppola »
IMPRESSIVE WORK! How long does it take to pickup the freecad API to create a custom workbench plugin? I am interested in creating a plugin for composites design.
jcoppola
Post by jcoppola »
Well i decided to dive into the API. Far so good i have some rudimentary surface peeling working in the python console. Eventually this will become a composite layup pattern and stress analysis tool.
Screenshot from 2021-11-18 04-17-20.jpg (163.17 KiB) Viewed 1706 times
apper001
Post by apper001 »
Just out of curiosity: how much physical RAM (RES MEM on Linux) does this 120MB model consume?
Good question, Bump
#lowhangingfruit | Use the Source, Luke. | How to Help FreeCAD | How to report FC bugs and features
apper001
Post by apper001 »
Bump again.....
