4 cylinder steam engine
un1corn
Post by un1corn »
Horizontal 4 cylinder rotary valve steam engine.
4CVR 5.JPG (297.46 KiB) Viewed 17335 times
4CVR 4.JPG (405.32 KiB) Viewed 17335 times
4CVR 3.JPG (275.95 KiB) Viewed 17335 times
4CVR 2.JPG (165.91 KiB) Viewed 17335 times
4CVR 1.JPG (193.69 KiB) Viewed 17335 times
bitacovir
Re: 4 cylinder steam engine
Post by bitacovir »
Spectacular!
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
triplus
Post by triplus »
Nicely done!
dubstar-04
Post by dubstar-04 »
That looks fantastic! Thanks for sharing!
user1234
Post by user1234 »
Looks very good! But are the teeth of the bevel gear functionally?
Greetings
user
ickby
Post by ickby »
Nice one! What is the reason to have the 180° differential of the pistons, and not 90°? As it is now you have a dead point where no force can be created (the situation shown in the pictures), but with each piston rotated by 90° you could have continuous force, which allows a smaller flying wheel.
herbk
Post by herbk »
ickby wrote: Mon Aug 19, 2019 6:55 am As it is now you have a dead point where no force can be created (the situation shown in the pictures), but with each piston rotated by 90° you could have continuous force, which allows a smaller flying wheel.
Hi ickby,
if the force of the pistons is at 180° (like it is) the force is straight to the direction of the piston movement.
If you work with 90° you get aditional bending forces and oscillations, which needs a much more strong case. - May be the vibrations gets so strong that it's not possible to deal with...
Thats also the reason why a reguler 4 cylinder engine never has the working order 1 2 3 4.
Gruß Herbert
un1corn
Post by un1corn »
As well as agreeing with Herbk comments, this is how the model is presented in the plans.
realgrm
Post by realgrm »
Hi, nice project.
Since I'm new here, I'm wondering if there is a way to download the 3d model to open in FreeCAD. I can only see the images.
I'm taking motor combustion classes and play with this model would be nice!
triplus
Post by triplus »
realgrm wrote: Thu Sep 05, 2019 12:20 am Hi, nice project.
Indeed, it looks like @un1corn didn't share the FCStd file. Best to wait for his response, regarding that.
Reason: edited to remove superfluous discussion
