Sheet metal WB 2018
Joel_graff
Re: Sheet metal WB 2018
Post by Joel_graff »
Added Sheet Metal WB to the 0.19 release notes.
https://www.freecadweb.org/wiki/Release ... al_Modules
FreeCAD Trails workbench for transportation engineering: https://www.github.com/joelgraff/freecad.trails
pivy_trackers 2D coin3D library: https://www.github.com/joelgraff/pivy_trackers
-alex-
Post by -alex- »
Joel_graff wrote: Sun Mar 10, 2019 10:48 pm Added Sheet Metal WB to the 0.19 release notes.
Thanks a lot Joel for adding to release notes. FYI maybe could you add this thread to the "discussion" links: https://forum.freecadweb.org/viewtopic.php?f=10&t=11303
-alex-
Post by -alex- »
Here I would like to share some sheet metal stuffs.
Last months I have tested some workflows about converting 3D solid to sheet metal part.
Basicaly the process is pretty similar with the one discribed by Jaisejames in his thread "Solid Shape to Sheet metal Tutorial":
https://forum.freecadweb.org/search.php ... 9&sr=posts
The aim is to work from faces of the model. IMHO I think my workflow is sharper and allows to get smouth links beetween sheet metal parts (better for MIG welding). To get this I always start from inner faces of the shell.
I'll will talk about that later in a tutorial, because for now there is a small bug/limitation about a function of freecad witch make the workflow tricky.
Anyway, below are some pictures of the FC logo: from picture to 3D solid to 3D sheet metal to flattened sketches.
Enjoy.
Alex
Joel_graff
-alex- wrote: Thu Apr 11, 2019 5:33 pm
Will do!
For future reference, feel free to post any updates to your workbench in the Release Notes thread:
https://forum.freecadweb.org/viewtopic. ... 6&start=80
-alex- wrote: Thu Apr 11, 2019 6:08 pm Here I would like to share some sheet metal stuffs.
Please post your work to both the tutorial subforum and the User Showcase forum. Thanks!
meme2704
Post by meme2704 »
Hi
Since I use Fc V0.19pre, my version of SheetmetalWb that was working with V0.17, does not work anymore, I can not find the links for the latest version (Windows7)
meme2704 wrote: Sat Apr 13, 2019 3:15 pm Since I use Fc V0.19pre, my version of SheetmetalWb that was working with V0.17, does not work anymore, I can not find the links for the latest version (Windows7)
How about update in AddonManager? (Yes, there are things better than in 0.16 ;) )
meme2704
Post by meme2704 »
super it's run again
thanks
chrisb wrote: Sat Apr 13, 2019 3:53 pm
This is a good point to have a ticket that reminds the user to update said workbench if it is obsolete
Edit: nvm, opened one a while ago: https://github.com/FreeCAD/FreeCAD-addons/issues/95 :oops: :lol:
NormandC
Post by NormandC »
It is also already working! But only if you have python-git installed, or python3-git when FreeCAD is built with Python3.
