Macro to compute center of mass
schupin
Post by schupin »
Hi all,
I just created my first macro for FreeCAD !
It's a small macro to compute the weight of multiple solids and the center of mass of the "assembly".
You have to select one or multiple solids and then you launch the macro.
You'll have a window listing the solids. You can put the density of your material or choose in a huge list of predefined materials (I took the values here)
If you know your densities in another unit system, I used FreeCAD convert system to propose differents units.
You can also display where is the center of mass :
You can save the computed information in a csv file :
A import button allows you to quickly loaded saved densities (even if it's not a .csv file with the macro, as soon as there is a column named "Density" it will be loaded.)
If anyone want to test or have any suggestion to improve it, here is the file :
Files are here : https://github.com/chupins/FreeCAD-macr ... nformation
PS : the design is from here : planosconciri
Icon pack :
CenterOfMass_iconPack.zip
(16.3 KiB) Downloaded 899 times
CenterOfMass_cionPack.zip
(16.3 KiB) Downloaded 181 times
thschrader
Re: Macro to compute center of mass
Post by thschrader »
Nice tool!
It is easy to generate a material list.
Can you extend the macro for rebars (=arch-structure object)?
rebars.FCStd
(200.21 KiB) Downloaded 211 times
bernd
Post by bernd »
why not choose the material out of the FreeCAD materials. They have density too.
schupin
Post by schupin »
thschrader wrote: Mon Oct 29, 2018 1:54 pm Nice tool!
I'll look at it. I'never work with arch, but it might be possible
bernd wrote: Mon Oct 29, 2018 6:51 pm why not choose the material out of the FreeCAD materials. They have density too.
It's my first macro and i didn't dive deeply into freecad API.
It was easier to start with this dictionnary. I guess i will easily change it to freecad's material list.
I'll try it soon
triplus
Post by triplus »
schupin wrote: Sun Oct 28, 2018 2:51 pm Hi all,
Congratulations and thanks for sharing.
schupin
Post by schupin »
thschrader wrote: Mon Oct 29, 2018 1:54 pm Can you extend the macro for rebars (=arch-structure object)?
That's done !
I also add some lines to make it work with arrays (and arrays of rebars).
If you know some other structures of this kind, let me know !
(I also have to add the pathArray support)
I now use FreeCAD's material list and editor.
I'm not fully convinced since there is not a lot materials within the freeCAD installation files (except if you work with any kind of steel :lol:).
But it's definitely better when you have already made a database.
I also change the button to icons to save place in the interface.
Here is the new version and the icons
CentOMassesIcons.zip
(67.01 KiB) Downloaded 198 times
CentOMasses.FCMacro
(27.9 KiB) Downloaded 231 times
galou_breizh
Post by galou_breizh »
It looks like a great macro. Can I put it on the official macro repositories (i.e. do you accept that other people can modify your macro)? What license do you want? I suggest the same as FreeCAD itself.
Thanks,
Gaël
schupin
Post by schupin »
galou_breizh wrote: Sat Nov 10, 2018 6:40 am It looks like a great macro. Can I put it on the official macro repositories (i.e. do you accept that other people can modify your macro)? What license do you want? I suggest the same as FreeCAD itself.
I'll be glad you add it in the official repo !
The same licence as FreeCAD is ok for me, but I'm not sure the icons I took are compatible with this licence ? (I took them from freepik) It's on CC 3.0 licence.
thschrader
Hi schupin,
macro and export to csv works for rebars.
But there is something wrong with the values (970 gramms total for the stirrups?)
Can you have a look at this? Thanks.
rebar_test.FCStd
(278.26 KiB) Downloaded 169 times
I am running on
OS: Windows 10
Version: 0.18.15072 (Git)
Hash: e517c00d9b3da3d1dbe5d5b0159ac5fa95790a8f
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
schupin
Post by schupin »
thschrader wrote: Sat Nov 10, 2018 12:26 pm Hi schupin,
You're right, It took the volume of only one element of the rebar.
It's corrected !
For your file it gives that :
I also corrected the units in the export data sheet (everything was in mm in the previous version)
CentOMasses.FCMacro
(29.13 KiB) Downloaded 251 times
