controling shear punching of Foundation
Re: controling shear punching of Foundation
ebrahim raeyat wrote: Tue Oct 25, 2022 5:21 pm 8- finally export the model into *.f2k file that can import into the CSI SAFE software:
Can the above dialog be re-formatted to show 2 columns of radio buttons instead of 1?
ebrahim raeyat
Post by ebrahim raeyat »
sure, done with https://github.com/ebrahimraeyat/OSAFE/ ... 265a7d618b:
Nice, thanks!
ebrahim raeyat
Adding Required reinforcement if punch ratio exceed 1:
User can change the value of Use_Reinforcement to true for calculating punch rebars. Program calculate distance between rebars and the total distance that rebars must be set, for example for corner column with punch ratio = 1.41, we must set 3T12 as hook in each branch of foundation with distance of 10 cm until 1.9 meter from column center:
I have the strong feeling that this topic should be moved, because it is more than a show case, but I'm unsure where to; Announcements? Open discussion?
ebrahim raeyat
I will add Automatic Creation of Main Bottom and Top Rebars for foundation with respect to location of openings in foundation.
