glider workbench
looo
Re: glider workbench
Post by looo »
Mx74
Post by Mx74 »
https://vimeo.com/360754349
Next step for OpenGlider ? :-)
looo
Post by looo »
Mx74 wrote: Mon Sep 30, 2019 2:08 pm by Mx74 » Mon Sep 30, 2019 3:08 pm
thanks for the link. We are developing also in this direction, but this is very difficult stuff:
https://github.com/booya-at/paraFEM
datecru
Post by datecru »
Hi, anyone have a video tutorial or could explain the installation process?, i try everything and i can't do it :cry:
looo
Post by looo »
Using conda:
conda create --name <env_name> freecad openglider  -c openglider -c freecad/label/dev -c conda-forge
to run freecad:
conda activate <env_name>
For conda install the latest version of miniconda (currently python3.7):
https://docs.conda.io/en/latest/miniconda.html
For help on how to use conda, best to have a look at the docs available:
or search for a video tutorial
other packagemanager:
If you want to install on linux distro. Best to have a look at the dependency section of the library and install the libraries with system package-manager. https://github.com/booya-at/OpenGlider/ ... quires.txt
Once done clone the openglider library and install it:
git clone https://github.com/booya-at/OpenGlider
cd OpenGlider
pip install -e --no-deps .
But this way some features are not enabled (mainly some meshing tools and flow-simulation).
svenair
Post by svenair »
looo wrote: Fri Dec 11, 2015 4:56 pm Announcing the glider workbench, a gui for OpenGlider in freecad. Development is still ongoing, but I thought it is time to show the development state. If someone is interested in testing or developing I can give instructions on how to install OpenGlider and this workbench.
It looks like it is a very useful and nice Workbench!
I had Interest to play with this..
But to install looks for me a bit difficult..
I had many happy Time under Paragliders and now more under Hanggliders..
https://www.youtube.com/watch?v=rKJmh9sq5x8&t=242s
Are you in this Buisyness?
I started Paragliding 1989..
This workbench seems to be interesting for quite a lot of people. Should it be integrated in the Addon manager?
looo
Post by looo »
chrisb wrote: Sun Nov 17, 2019 11:21 am This workbench seems to be interesting for quite a lot of people. Should it be integrated in the Addon manager?
Not possible to due difficult (compiled) dependencies (mainly parabem, meshpy). We provide easy installation with conda. In my mind this is a good compromise between maintainability and simplicity to install.
looo
Post by looo »
svenair wrote: Sun Nov 17, 2019 11:06 am Are you in this Buisyness?
Not really, but we are planning to release one of the designs mentioned in this topic.
svenair
Post by svenair »
Interesting..
The Software makes a good look for work, when it is easyer to install or when I'm having some Time, I will test.
