glider workbench
ibbono
Re: glider workbench
Post by ibbono »
I try to "pip Install" openglider for freecad, but I can't find the workbench... Anyone has the same problem?
ibbono
Post by ibbono »
ibbono wrote: Sun Nov 24, 2019 2:21 pm I try to "pip Install" openglider for freecad, but I can't find the workbench... Anyone has the same problem?
The Pip Install went good, but I can't find in freecad-workbench glider? Any tips?
1) Someone can explane step by step how to install the add on?
2) Is there any other app to install to make it work?
Thank you very very much...
I'd like to help develop this stuff...but first id like to make it work on my computer....
looo
Post by looo »
you need to install the dependencies (see link below)
ibbono wrote: Sun Nov 24, 2019 6:31 pm 1) Someone can explane step by step how to install the add on?
https://forum.freecadweb.org/viewtopic. ... 90#p346883
Installing with conda is the simplest way. It should work on mac, linux and windows.
looo wrote: Mon Nov 25, 2019 8:36 am https://forum.freecadweb.org/viewtopic. ... 90#p346883
@looo is there a section to the workbench README to add these instructions on how to install conda? (it could be in an optional collapsed div)
#lowhangingfruit | Use the Source, Luke. | How to Help FreeCAD | How to report FC bugs and features
looo
Post by looo »
Kunda1 wrote: Mon Nov 25, 2019 11:20 am @looo is there a section to the workbench README to add these instructions on how to install conda? (it could be in an optional collapsed div)
now there is a short section:
https://github.com/booya-at/OpenGlider/ ... with-conda
looo wrote: Tue Nov 26, 2019 4:30 pm now there is a short section:
:+1:
ibbono
Post by ibbono »
I install all the dependenices, (git clone) i install openglider, but then, whan i open freecad i didn't see the workbench, what can i do?
looo
Post by looo »
As said it's more difficult to install other than with conda. So if you really want to try this workbench, best to use conda.
- install conda
- make yourself comfortable with environments
- install all the utilities with:
conda create openglider openglider freecad.python freecad -c openglider -c freecad/label/dev -c conda-forge
I can't help more, sry.
rubylion
Post by rubylion »
WOW :shock:
This is crazy. Too bad I'm not paragliding. And if I did I'm not sure if I'd construct my own glider (to the grave?)
But anyways. Very impressive
looo
Post by looo »
rubylion wrote: Fri Dec 20, 2019 2:56 pm WOW :shock:
There are also more useful applications:
https://www.youtube.com/watch?v=vMTchVXedkk
www.kps.energy/
