But i think there should not be much problem with hand soldering - i'm assuming it is 1.25mm grid? Just some practice and good equipment.
Also it is simple blinker (or multivibrator if i correctly remember name)?
Thank you. I tried to solder the PCB's twice, yes i did two PCB's. And i could not do it. The main problem was the space between the pins of the transistor. The lack of the silk screen didn't do any favour either.
j8sr0230 wrote: ↑Fri Aug 05, 2022 10:32 am Hi community,
the video shows my fork of the node editor pyqt-node-editor (https://github.com/j8sr0230/pyqt-node-editor) as a possible alternative to the well-known PyFlow editor. After some work to integrate pyqt-node-editor into FreeCAD's parametric system in a meaningful way, I am now working on the implementation of FreeCAD-specific nodes.
It shows a revolved part created with a BSPline curve. I modeled the BSpline curve parametrically with the nodes shown. The whole system remains parametric even after manipulating the base curve. I think I will implement my macros step by step as nodes and publish them. As always: Work in progress![]()
