Fix inconsistent properties of Draft annotations?
Roy_043
Post by Roy_043 »
There are some inconsistenties in the properties of Draft annotations. This is confusing for both end users and programmers. IMO this should be improved. But any change to these properties would mean introducing functions to convert old objects that would have to stay in the Draft code for a long time.
Draft_Text:
DisplayMode: 3D text/2D text ("2D text" means the text faces the camera)
FontName
FontSize
LineColor (not used)
TextColor
Draft_Dimension:
DisplayMode: 2D/3D ("3D" means the text faces the camera)
FontName
FontSize
LineColor (also used for the text)
Draft_Label:
TextFont
TextSize
LineColor (used for leader, arrow and frame)
TextColor
Roy_043
Re: Fix inconsistent properties of Draft annotations?
Post by Roy_043 »
For the LineColor of annotations the DefaultShapeLineColor preference is now used. This is questionable IMO.
carlopav
Post by carlopav »
I've never realized It... I'm for fixing It, also if this means adding some backward compatibility code...
follow my experiments on BIM modelling for architecture design
Roy_043
Post by Roy_043 »
My suggestion would be to change the DisplayMode options to Screen/World. This avoids the 2D/3D confusion.
See: https://forum.freecadweb.org/viewtopic.php?f=23&t=58335
