LineSegments to one line in sketch
NEP_11
Post by NEP_11 »
I have a profile of a part in sketch, it is formed by several lines (lineSegments) and I am trying in every possible way to make it a single continuous line. Not visually, but in the "Elements" box, I am trying to make it a single line, and then revolutionize the profile to be a single surface instead of several faces.
Attached my code of the lines that I need to be a single line.
Could you please tell me if this can be done?
The constraints do not work for me in this case because they only join lines visually.
Thanks in advance
prueba.FCStd
(6.85 KiB) Downloaded 25 times
Re: LineSegments to one line in sketch
You can use a B-spline made in Curves WB, but may I ask why you want this?
