How to division landing of Arch Stair
I'm going to make a step difference with two landing instead of one landing on the landing of the stairs. However, none of the stair properties I create can divide the landing.
- 2022-09-26.png (298.27 KiB) Viewed 882 times
- papyblaise
Re: How to division landing of Arch Stair
this one
- stair.FCStd
- (34.86 KiB) Downloaded 24 times
- stair.JPG (25.03 KiB) Viewed 851 times
@papyblaise
Thank you for your answer. But, was you answer has somthing wrong that I meant I want extrude of 10 step of the numbers. Please check this.
- 2022-09-27.png (260.82 KiB) Viewed 769 times
- papyblaise
10 step for you
- stair.FCStd
- (53.23 KiB) Downloaded 25 times
Indeed needs some works to make this works, see attached / screencapture.
Please make a feature request. Moving to Arch/BIM Wb to see if there is interest to improve it
(More discussion here for reference https://forum.freecadweb.org/viewtopic.php?f=23&t=29358)
