{Solved} - Mirror sketch and Sketcher Symmetry Problem/Question
Palmtree
Post by Palmtree »
Problem 1- Mirror sketch:
I have attached a test file (Test Sheetig Profile.FCStd)
Open file ==> Highlight all (Before entering edit sketch) ==> Sketcher Mirror ==> Y-Axis (Image 1) ==> Wrong/Strange result (image 2)
Problem 2- Sketcher Symmetry:
Click to enter Edit Sketch ==> Sketcher Symmetry (Image 3) ==> Wrong/Strange result (image 4)
Am I missing something? Please confirm this problem? any comment?
Version: 0.21.30305 (Git)
Hash: 5ffc2e10b69971e2cdcd798c4deacf44d407fd77
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.2
  * Behave-Dark-Colors 0.1.1
  * BIM 2021.12.0
  * Design456 0.0.1
  * dodo
  * Dracula 0.0.2
  * fasteners 0.4.3
  * Help 1.0.3
  * Parts_library
  * PieMenu
  * Reinforcement
  * SketchArch
Test Sheeting Profile.FCStd
(478.03 KiB) Downloaded 31 times
Image 1.jpg (268.44 KiB) Viewed 918 times
Image 2.jpg (246.95 KiB) Viewed 918 times
Image 3.jpg (321.97 KiB) Viewed 918 times
Image 4.jpg (256.65 KiB) Viewed 918 times
Palmtree
Re: Mirror sketch and Sketcher Symmetry Problem/Question
Post by Palmtree »
Palmtree wrote: Fri Sep 16, 2022 5:27 am Problem 1- Mirror sketch:
I have been looking for a work around and I have found one I would like to share.
Download the file from the post before (Test Sheeting Profile.FCStd) ====>
Select Sketch001 (Image 1) => Downgrade => Upgrade => Wire => Select Wire => Converts Draft to Sketch => Select Sketch => go to sketch WB (Before entering edit sketch) => Sketcher Mirror ==> Y-Axis ==> Done ==> Mirror sketch OK (Image 2)
Similarly no problem for Sketcher Symmetry (copies the profile symmetrical to a chosen line – Image 2)
I am confused :? :? :? . Is this a bug? :?: :?: :?: I wish if some body can confirm my reported Problem/Question :) :) :)
Version: 0.21.30454 (Git)
Hash: 5df954690787dedbbf3c35f658f010f388474676
  * BIM 2021.12.0
  * Design456 0.0.1
  * dodo
  * Dracula 0.0.2
  * fasteners 0.4.10
  * Help 1.0.3
  * Parts_library
  * PieMenu
  * Reinforcement
  * SketchArch
Image 1.jpg (258.39 KiB) Viewed 700 times
Image 2.jpg (347.08 KiB) Viewed 700 times
Image 3.jpg (322.08 KiB) Viewed 700 times
Bance
Post by Bance »
This is not a bug, the sketcher solver accepts the first solution to the possible constraints. It does not mean that it is the only solution.
In some cases there are more than one possible outcome. When this happens the vernacular description is 'Flipping'.
A different set of constraints may solve the problem.
This one of the reasons it is recommended to use fractional sketches and make mirrors/patterns in the solid form.
HTH Steve.
Palmtree
Post by Palmtree »
Bance wrote: Thu Sep 29, 2022 9:41 am This is not a bug, the sketcher solver accepts the first solution to the possible constraints. It does not mean that it is the only solution.
HTH Steve.
@Bance Now I understand. :) :) :). Many thanks to your prompt response. :D :D :D
Palmtree
Post by Palmtree »
Bance wrote: Thu Sep 29, 2022 9:41 am In some cases there are more than one possible outcome. When this happens the vernacular description is 'Flipping'.
Dear Forum member,
If you have come across this Problem/Question (similar to me) and have never knew about "flipping" yet. I have attached a link to a post (Sketcher - solving the flipping problem), it might be helpful. :lol: :lol: :lol:
https://forum.freecadweb.org/viewtopic.php?t=10872
