I have started working on 2 features:
Redesigning the properties system https://github.com/yorikvanhavre/BIM_Wo ... /issues/81 and
Native IFC support https://github.com/yorikvanhavre/BIM_Wo ... /issues/94
So far, there is now a new IFC importer in the BIM WB. Just make sure Edit -> Preferences -> import/export -> IFC -> multicore is above 0. Then it's just a matter of selecting the IFC BIMWB importer in the list. If you use latest master code, the BIM WB importer is automatically detected and used (if using multicore) so there is nothing else to do.
What it does so far:
- It creates an entry in the document Meta storing a reference to the original IFC file
- Misc fixes and improvements here and there
- IFC properties are now imported and mapped to real FreeCAD properties. This is the biggest change and I'd like some feedback on it, if anyones fancies testing. To me it looks pretty cool and I see no real performance difference... But if it turns out to be bulky or heavy or impractical, we see another solution
IFC improvements
- thomas-neemann
Re: IFC improvements
it sounds like the import is significantly faster. Marvelous. Many Thanks
On my older computer (intel i7), multicore didn't work very well, I had to leave it on 1 (even so, it's much faster than the basic importer). With the new one (amd ryzen 9) multicore works and it improves speed even more (up to 4. Above that, it doesn't really make much difference)..
- thomas-neemann
- proghettolab
WB BIM version 2021.12.0 - FreeCAD 0.20.1
On 11th Gen Intel® Core™ i7-11700 @ 2.50GHz × 16 - Ram 64 GB
From 1 to 16 core the result is:
Finished importing 3.1 Mb in 00:11 s, or 3 s/Mb
0 core > it doesn't work.
- HenriqueReis
I performed the update and configuration, with multicore at 1. I opened 5 IFC files in a matter of seconds. A curiosity that I really liked is that it generated the Global ID in the objects.
OS: Ubuntu Core 20 (Budgie:GNOME/budgie-desktop)
Asus - Core i5 3rd Gen - 8GB Ram
Version: 0.20.1.29177 +233 (Git) Snap 245
Branch: tag: 0.20.1
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.3
Locale: Portuguese/Brazil (pt_BR)
* BIM 2021.12.0
This makes me wonder if "IFC" and "IFC Attributes" groups shouldn't become one...
