Stacktrace on BIM project sample loading
esteban.dugueperoux
Post by esteban.dugueperoux »
Hello FreeCAD community,
I follow https://wiki.freecadweb.org/Manual:BIM_modeling and as I encounter issue with dimension, I try to load the final result project, i.e. https://github.com/yorikvanhavre/FreeCA ... ouse.FCStd.
But when loading the file I get following stacktrace:
08:21:26  Traceback (most recent call last):
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1086, in attach
    self.onChanged(vobj,"CutView")
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1162, in onChanged
    sg = FreeCADGui.ActiveDocument.ActiveView.getSceneGraph()
<class 'AttributeError'>: getSceneGraph
  File "/usr/lib64/freecad/Mod/Arch/ArchSectionPlane.py", line 1106, in updateData
    self.onChanged(obj.ViewObject,"CutView")
I get the error on Linux Fedora 36 with FreeCAD 0.20 installed from Fedora official repos.
The 3D scene seems correctly displayed.
P.S.: I have attached the complete logs of BIM project loading.
freecadBug.log
(6.96 KiB) Downloaded 4 times
paullee
Re: Stacktrace on BIM project sample loading
Post by paullee »
Moved to Arch/BIM sub-forum hopefully for more exposure :)
@esteban.dugueperoux thanks for the post. Please also add your full About info
#lowhangingfruit | Use the Source, Luke. | How to Help FreeCAD | How to report FC bugs and features
Roy_043
Post by Roy_043 »
Confirmed. It is related to how the file was saved (with the Drawing Page active). If you close the Page, save and reopen, the problem does not occur.
If the main view shows a Drawing Page there is an FreeCADGui.ActiveDocument.ActiveView object, but this object does not have a getSceneGraph method.
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
esteban.dugueperoux
It is strange because "Gnome Software" tells me that I have release 0.20.1 while FreeCAD itself indicates me 0.21:
OS: Fedora Linux 36 (Workstation Edition) (GNOME/gnome)
Version: 0.21.Unknown
Build type: Unknown
Python 3.10.6, Qt 5.15.5, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.0
Locale: French/France (fr_FR)
  * parts_library.bak
  * fasteners 0.3.51
  * parts_library
  * A2plus 0.4.56a
It's a packaging issue. 0.21 is development release and is a moving target. So it should really be represented as 0.21.xxxxx (this variable correlate to the revision number, it's the number of commits you see when you look at FreeCAD/FreeCAD Github commits)
esteban.dugueperoux
I believe it's on our end, issue #5945
